YZ SHADOW and MPC STAR PLAYER
I am using Win XP and YZ Shadow 1.9 program to get my windows shadow. The problem is when i want to run any function (like video settings or subtitles) in MPC, the program stop working. Everything is ok if i disable YZ Shadow. Is there any chance to fix that or any help for this problem. MPC Star player is very good so far and i dont want to use a different program for playing videos.
Many thx for help.
By
Problem solved. I used Exclude in YZ Shadow for each open window in MPC.
