silverfirefly123 Posted July 27, 2006 Share Posted July 27, 2006 Hi, I've download a film but it's split into 2 avi files, is there anyway of convert the two files into 1? :( Link to comment Share on other sites More sharing options...
caf4926 Posted July 28, 2006 Share Posted July 28, 2006 windows movie maker will do it and there are many other programs too, the list is endles, go here http://www.videohelp.com/tools?s=108#108 Virtual dub is another Link to comment Share on other sites More sharing options...
nsevilgenius Posted July 28, 2006 Share Posted July 28, 2006 the best is camstasia studio you can even make it smaller if you need to' Link to comment Share on other sites More sharing options...
kluelos Posted July 29, 2006 Share Posted July 29, 2006 Your reason for doing this could make a huge difference in what to recommend. If you just want to past them together (why?), that's a whole lot different from, say, trying to fit them onto a single disk, which would involve shrinking, and maybe converting. OTOH, maybe you don't need to join them to achieve whatever you're trying to do. Link to comment Share on other sites More sharing options...
