Tracker connect problem : a tracker call that should never fail has failed - Bug of Bitcomet and how to solve !
I just found out that if u use the TCP/IP limit mode of Bitcomet and modify the tcpip.sys u'll receive a error responce of tracker : A tracker call that should never fail has failed <_< . If u already did it all u have to do now is replace the tcpip.sys (modified) with the original one
1/delete the tcpip.sys in driver folder of window
2/change tcpip.sys.original to tcpip.sys
3/if u havent disabled the window protection u'll have to put the window CD into ur CD and waiting for it to replace the file !
OK now start bitcomet again and the problem solved !
Also this is a bug of Bitcomet . If u dont use the TCP/IP limit of Bitcomet to change half connection but use this one instead ! u wont get the tracker problem
P/s : For Winxp not sure about vista and 7 !
Edited by DevilsOrAngels (see edit history)
