gof_3 Posted August 28, 2009 Share Posted August 28, 2009 (edited) Hi to All My name is gof_3 and am new to the forum. :) My problem is with trackers etc: it says "an established connection was aborted by the software in your host machine, also I get this to UDP Tracker no responce :( Edited August 28, 2009 by gof_3 (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 28, 2009 Share Posted August 28, 2009 Hi, can you please review the "READ THIS before posting", and reply with the details regarding your computer and bitcomet versions. I'd also like you to prepare a screenshot of this error message. If you don't know how, I believe we have a guide for making and posting screenshots in the guides/tutorials section. Lastly, does this happen with all torrents, or just one? if just one, can you please post a link to where you got this torrent so we can examine it. TuuS Link to comment Share on other sites More sharing options...
gof_3 Posted August 29, 2009 Author Share Posted August 29, 2009 (edited) Thanks for you reply sorry if I poted wrong but am new to posting. I am using Windows XP serv. Pack 3 Bitcomet ver. is 1.14 I keep it updated to latest ver. internet connection is ADSL2+ using a modem only all ports are forwarded correct hopefuly Using windows firewall only, download speeds are ok set to unlimited. Antivirus used is AVG 8 This problem has occured before in other versions of Bitcomet. Thanks also for info on screenshots never did that before. Edited August 29, 2009 by gof_3 (see edit history) Link to comment Share on other sites More sharing options...
kluelos Posted August 29, 2009 Share Posted August 29, 2009 The tracker you're trying to connect to has been experiencing problems. You should try again and see if the issue persists. If it does, what antivirus application are you using? Link to comment Share on other sites More sharing options...
gof_3 Posted August 30, 2009 Author Share Posted August 30, 2009 the antivirus I'm using and have used for some time now is AVG 8.5 licienced. Have also noticed SumoTorrent does the same. Gof_3 Link to comment Share on other sites More sharing options...
