skyleung88 Posted August 28, 2009 Share Posted August 28, 2009 Hi everyone. I just moved into an Canadian university, where resnet is used in all dorms. I am sure that they don't prohibit bittorrent softwares, such as BitComet. But they do impost a bunch of restrictions. Recently, once I opened the Bitcomet, they will put me into the penalty box due to the reason that I've exceeded a limitof 3000 connections. So is there anything I could do by setting the Bitcomet itself a connection maximum number to avoid such penalty. Need help very urgently! Thank you! Link to comment Share on other sites More sharing options...
Vasy Posted August 28, 2009 Share Posted August 28, 2009 Hi! Go to options, advaced, and change the value of network.max_connections to the limit you want(a lot lower than 3000 as I am sure that you use your internet connection for something else than bittorrent too) Cheers! Link to comment Share on other sites More sharing options...
Dark_Shroud Posted August 28, 2009 Share Posted August 28, 2009 You can disable DHT to limit the number of connections you'll make. Link to comment Share on other sites More sharing options...
Vasy Posted August 29, 2009 Share Posted August 29, 2009 Um..DHT uses udp, udp is connectionless thus no connections are made. am I right? Link to comment Share on other sites More sharing options...
greywizard Posted August 29, 2009 Share Posted August 29, 2009 @ Vasy: I'm not sure how their ISP monitors the number of connections but it may be that they monitor just the number of ports reserved by one IP in the border gateway router(s) and thus UDP "connections" would count as connections, I think, since they still use a pair of sockets. Link to comment Share on other sites More sharing options...
