Firefox Problem
Callum
Hallo,
I often use Firefox, a great browser, and sometimes go to Tools - Options - Security - saved password to read and erase the passwords for the sites that I visit.
Do you know if there is a way to shorten this path, maybe insert something in the toolbar to speed up this task?
Thank you
__________________
(Mod. Edit - Removed spam links from signature.)
Hi! In the versions prior to (and including) 3.0 you had Tools=>Delete private data, and it had the "Delete saved passwords" option.
I don't think there is a hot key for that, so.. yes! you have to go to Tools > Options > Security.
But why do you save the passwords if you don't need them?
Cheers m8!
