najaraja Posted October 23, 2009 Share Posted October 23, 2009 I seem to be having a problem with my passport panel. It may not be a huge issue but I wasn't sure if this would affect my download/uploads at all. As you can see, the page won't load and it says that it is probably because I don't have a specific file I need. When I click on the option that says "Search online for the download" nothing happens. Also, down at the bottom it shows that I am logged in so I'm not sure if I am showing up as logged in and whether or not it was that big a deal. I am using version 1.15 on windows xp. I have a cable modem and a linksys router. Port is forwarded and I have a static ip address. Thanks for the help in advance :) Link to comment Share on other sites More sharing options...
greywizard Posted October 24, 2009 Share Posted October 24, 2009 Read here about passport. As for checking if you are really logged on to passport, just head, for example, to http://www.tocomet.com/ while BitComet is running. Check the right-hand upper corner of the page. If you are logged in, that means you are logged on the passport and were automatically logged on the site. Try a clean reinstall of BitComet to see if it fixes your problem, if it nags you. Link to comment Share on other sites More sharing options...
