DeadRurouni Posted November 14, 2009 Share Posted November 14, 2009 Hi all, I'm currently facing the problem with DL speeds/rates. I'm currently DL-ing one task, and it goes around 60-70kb/s, however, Bitcomet shows me that it is downloading at 200-400kb/s! When I check my bandwidth usage, it really is going at 200-400kb/s, but I'm absolutely positive I'm only DL-ing one task. Help! I started having this problem when I switched to 1.16. I'm currently back at 1.15, but still having the same problem. I'm connected to the internet via a usb device plugged in to my com's usb port. So no routers or anything. I'm using Windows XP Home. Anti-virus is AVG Anti-Virus Free. Would really appreciate any help I can get =) Thanks! Link to comment Share on other sites More sharing options...
greywizard Posted November 14, 2009 Share Posted November 14, 2009 What type of Internet connection do you have? At what speed? Where in BitComet do you see the 200-400 speeds? Link to comment Share on other sites More sharing options...
kluelos Posted November 14, 2009 Share Posted November 14, 2009 You're also being pretty careless with your units, and that may be the root of your problem. A Byte = 8 bits. One bit is too small to be of much use in most applications including Bittorrent, so we measure everything including speed, not in Kilobits, but in KiloBytes. 1 KB = 8 Kb. Capitalization is everything. You need to make sure all of your measurements use the same units. Link to comment Share on other sites More sharing options...
