NEED HELP WITH CODES FOR BITCOMET CONVERTER
kron
The BC converter was evidently abandoned two years ago and hasn't been revised since the initial release. It's extremely buggy, doesn't keep a log to tell you what it's done, prompts in Chinese despite being set to English, won't use XVid or DivX , and writes 0-byte output files.
I've never had it actually work for FLV to video, and have never tried the other way. You're better off using something else to do your conversions. There are many out there.
