Bitcomet not starting
anam1
Hi,
I upgraded my software by uninstalling the older version and moving to 1.16 version through fresh install
It worked for 2-3 days and suddenly, it stopped working.
I tried to uninstall and reinstall several times, but its not starting, I see windows hourglass and nothing happens next.
I have even check my firewall setting and bitcomet has Allow mode.
Please guide me.
Bitcomet Version 1.16
WIMAX 1Mbps (Motorola)
Wifi TP-link (340G)
No port forwarder
WinXP Professional, Windows Firewall, Norton AntiVirus&versions=15.5.0.23
Have you tried starting it from the executable file instead of desktop/start menu shortcut? Does it do the same thing?
If yes, try disabling Norton AV before starting BC just to test how it behaves.
And check the event logs of Windows (Administrative Tools-->Event Viewer, especially the Application, System and Antivirus sections) for any events occurring at the exact moment when you try to start BC.
Also, please look in the task manager and see if there is any BC process, to check if BC starts without loading the GUI or it doesn't start at all.
