lasse Posted November 21, 2009 Share Posted November 21, 2009 Hi, When I run the installation file it only get a security warning and when I press "Run" nothing more happens. I am running ComitBird 3.5.5, Windows 7, 64 bit and downloaded the installation file from apphit. Lars Link to comment Share on other sites More sharing options...
greywizard Posted November 21, 2009 Share Posted November 21, 2009 ...it only get a security warning and when I press "Run" nothing more happens. Do you mean an User Account Control warning or what? What antivirus or security suite do you use? Please check the event log of Windows (Application, System, Antivirus) for any events which occur at the exact time when you attempt the installation. Also keep open the Task Manager and check if upon starting the installer the process gets created and subsequently gets killed or if it simply hangs. Link to comment Share on other sites More sharing options...
lasse Posted November 21, 2009 Author Share Posted November 21, 2009 (edited) Yes, I mean the UAC. I need to press run there. I am using avast! 4.8 professional virus scanner, only one that works well under 64 bit Windows. Not much in the event viewer. I tried to run process explorer but could not see much. Any ideas? Edited November 21, 2009 by greywizard (see edit history) Link to comment Share on other sites More sharing options...
greywizard Posted November 21, 2009 Share Posted November 21, 2009 I tried to run process explorer but could not see much. Well, that's not a very clear answer to my question. My question was: "Upon starting the installer, the process gets created and subsequently gets killed or does it get created and then simply hangs?" That's what you were supposed to see in the process list, not "much". What version are you trying to install? Try disabling UAC before installing and see what happens. Link to comment Share on other sites More sharing options...
lasse Posted November 22, 2009 Author Share Posted November 22, 2009 (edited) I saw the process start and go away in process explorer. See attached screen shoot. It then goes away after a while. Trying to install 3.5.5 I will try to disable UAC now requires a reboot of my system. Lars Please, use the "Reply" button, unless your intentions are to quote a specific line of a previous message. Edited November 22, 2009 by greywizard Removed full qutation (see edit history) Link to comment Share on other sites More sharing options...
greywizard Posted November 22, 2009 Share Posted November 22, 2009 Yeah, I can see now that we've been talking about different things. I was under the impression that you have problems with your BitComet installer. WHY post in the "BitComet General Discussion" area of the forum if your question was about CometBird? :blink: *** Topic moved *** Link to comment Share on other sites More sharing options...
lasse Posted November 22, 2009 Author Share Posted November 22, 2009 Sorry that was my mistake.. I will try to post there! Link to comment Share on other sites More sharing options...
lasse Posted November 22, 2009 Author Share Posted November 22, 2009 It seems to me that I was posting in the forum.. Comet Forums> CometBird & CometMarks> CometBird General Discussions isn't that correct? turning off UAC did not help. Lars Link to comment Share on other sites More sharing options...
greywizard Posted November 22, 2009 Share Posted November 22, 2009 Try and give a detailed hardware & software description of your system. (Be sure to mention any security suite you use.) If it turns out to be a bug, we will forward that to the developing team. Link to comment Share on other sites More sharing options...
lasse Posted November 22, 2009 Author Share Posted November 22, 2009 (edited) I am using avast! 4.8 anti virus.. I tried turning off on access protection and I still get the same crash. OK here are detailed hardware and software description generated with EVEREST. Hardware: +++++++++ Field Value Computer Computer Type ACPI x64-based PC Operating System Microsoft Windows 7 Ultimate OS Service Pack - Internet Explorer 8.0.7600.16385 DirectX DirectX 11.0 Computer Name I7 User Name las Logon Domain i7 Date / Time 2009-11-23 / 00:36 Motherboard CPU Type QuadCore Intel Core i7 920, 2800 MHz (21 x 133) Motherboard Name Asus P6T Deluxe V2 (2 PCI, 1 PCI-E x4, 3 PCI-E x16, 6 DDR3 DIMM, Audio, Dual Gigabit LAN, IEEE-1394) Motherboard Chipset Intel Tylersburg X58, Intel Nehalem System Memory 6135 MB (DDR3-1333 DDR3 SDRAM) DIMM1: Corsair XMS3 CM3X2G1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz) DIMM3: Corsair XMS3 CM3X2G1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz) DIMM5: Corsair XMS3 CM3X2G1600C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (6-6-6-16 @ 444 MHz) BIOS Type AMI (05/19/09) Display Video Adapter ATI Radeon HD 4770 (512 MB) Video Adapter ATI Radeon HD 4770 (512 MB) 3D Accelerator ATI Radeon HD 4770 (RV740) Monitor Eizo Nanao FlexScan S2000 (Digital) [20" LCD] (39628116) Multimedia Audio Adapter Analog Devices AD2000B @ Creative SB X-Fi Audio Controller Audio Adapter Analog Devices AD2000B @ Intel 82801JB ICH10 - High Definition Audio Controller Audio Adapter ATI Radeon HDMI @ ATI RV710/730/740 - High Definition Audio Controller Storage IDE Controller Intel® ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26 IDE Controller Intel® ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20 IDE Controller Standard Dual Channel PCI IDE Controller Floppy Drive Floppy disk drive Disk Drive WDC WD10EADS-00M2B0 ATA Device (931 GB, IDE) Disk Drive WDC WD740HLFS-01G6U0 ATA Device (69 GB, IDE) Optical Drive PIONEER BD-RW BDR-203 ATA Device (8x/2x/8x BD-RE) SMART Hard Disks Status OK Partitions C: (NTFS) 70908 MB (24174 MB free) E: (NTFS) 931.5 GB (86.8 GB free) Total Size 1000.8 GB (110.4 GB free) Input Keyboard HID Keyboard Device Mouse Microsoft USB Wireless Mouse (IntelliPoint) Network Primary IP Address 192.168.0.3 Primary MAC Address 00-26-18-08-5C-ED Network Adapter Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller Network Adapter Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (192.168.0.3) Network Adapter VMware Virtual Ethernet Adapter for VMnet1 (192.168.137.1) Network Adapter VMware Virtual Ethernet Adapter for VMnet8 (192.168.254.1) Peripherals Printer Canon MP960 Printer Printer Fax Printer Microsoft XPS Document Writer FireWire Controller VIA VT6306/6307 Fire II IEEE1394 Host Controller (PHY: VIA VT6307) USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller USB1 Controller Intel 82801JB ICH10 - USB Universal Host Controller USB2 Controller Intel 82801JB ICH10 - USB2 Enhanced Host Controller USB2 Controller Intel 82801JB ICH10 - USB2 Enhanced Host Controller USB Device Generic USB Hub USB Device Logitech Mic (Pro 9000) USB Device Logitech QuickCam Pro 9000 USB Device Logitech USB Camera (Pro 9000) USB Device Microsoft Mouse and Keyboard Detection Driver USB Device USB Composite Device USB Device USB Input Device USB Device USB Input Device DMI DMI BIOS Vendor American Megatrends Inc. DMI BIOS Version 0504 DMI System Manufacturer System manufacturer DMI System Product System Product Name DMI System Version System Version DMI System Serial Number System Serial Number DMI System UUID A0AA001E-8C0001E6-C2E20026-18085CEC DMI Motherboard Manufacturer ASUSTeK Computer INC. DMI Motherboard Product P6T DELUXE V2 DMI Motherboard Version Rev 1.xx DMI Motherboard Serial Number MS1C96B06700184 DMI Chassis Manufacturer Chassis Manufacture DMI Chassis Version Chassis Version DMI Chassis Serial Number Chassis Serial Number DMI Chassis Asset Tag Asset-1234567890 DMI Chassis Type Desktop Case DMI Total / Free Memory Sockets 6 / 3 Problems & Suggestions Problem Disk free space is only 9% on drive E:. Operating system: +++++++++++++++++ Field Value Operating System Properties OS Name Microsoft Windows 7 Ultimate OS Code Name Vienna OS Language English (United States) OS Kernel Type Multiprocessor Free (64-bit) OS Version 6.1.7600 (Win7 RTM) OS Service Pack - OS Installation Date 10/25/2009 OS Root C:\Windows Current Session Computer Name I7 User Name las Logon Domain i7 UpTime 1019 sec (0 days, 0 hours, 16 min, 59 sec) Components Version Common Controls 6.16 Internet Explorer 8.0.7600.16385 Windows Mail 6.1.7600.16385 (win7_rtm.090713-1255) Windows Media Player 12.0.7600.16385 (win7_rtm.090713-1255) Windows Messenger - MSN Messenger 14.0.8064.0206 Internet Information Services (IIS) - .NET Framework 3.5.30729.4926 built by: NetFXw7 Novell Client - DirectX DirectX 11.0 OpenGL 6.1.7600.16385 (win7_rtm.090713-1255) ASPI - Operating System Features Debug Version No DBCS Version No Domain Controller No Security Present No Network Present Yes Remote Session No Safe Mode No Slow Processor No Terminal Services Yes Lars Try and give a detailed hardware & software description of your system. (Be sure to mention any security suite you use.) If it turns out to be a bug, we will forward that to the developing team. Edited November 22, 2009 by lasse (see edit history) Link to comment Share on other sites More sharing options...
lasse Posted November 22, 2009 Author Share Posted November 22, 2009 It seems to work in my VMware Windows 7 64 bit.. but not on my host OS. Link to comment Share on other sites More sharing options...
lasse Posted November 22, 2009 Author Share Posted November 22, 2009 Downloaded again from the official release.. works now.. was a bad file from Apphit Link to comment Share on other sites More sharing options...
cassie Posted November 23, 2009 Share Posted November 23, 2009 It seems to me that I was posting in the forum.. Comet Forums> CometBird & CometMarks> CometBird General Discussions isn't that correct? Errr... not exactly. Wiz moved it for you... WHY post in the "BitComet General Discussion" area of the forum if your question was about CometBird? :blink: *** Topic moved *** Link to comment Share on other sites More sharing options...
