patteoh Posted November 30, 2009 Share Posted November 30, 2009 i have been using bitcomet for about 2 years...and never have such problem till 3 days ago. my listen port turn light grey and download is very slow. pls can anyone help and advise and make it turn to green. thank you Link to comment Share on other sites More sharing options...
fire_boy Posted November 30, 2009 Share Posted November 30, 2009 well i have the same and the port status shows detect failed neither unknown the old usual gray nor blocked the old usual yellow... ive never seen this b4 if its the same with u is it detect failed ?? and im sure my port is opened Link to comment Share on other sites More sharing options...
greywizard Posted November 30, 2009 Share Posted November 30, 2009 The Comet server which BitComet uses to check the status of your connection seems to be down at the moment. But that shouldn't bear any impact on your downloading speeds except if you really had a blocked port (a.k.a. yellow light even before this happened). For more info on another means to check your connection's status read this topic. Link to comment Share on other sites More sharing options...
