joder666 Posted December 15, 2009 Share Posted December 15, 2009 Ok i'm new using bit comet and member of demoniod, and i'd to know if there's a way to increase my ratio using bit comet on demonoid. As far as i know on the FAQ at demoniod says that bit comet and its derivatives aren't compatible. Link to comment Share on other sites More sharing options...
kluelos Posted December 15, 2009 Share Posted December 15, 2009 BitComet is perfectly compatible with Demonoid. I've been using it there for years. I would stay away from the Demonoid forum, though. It's a pretty toxic, appallingly ignorant group. Fortunately, they actually have nothing to do with running Demonoid itself. Increasing your ratio there is the same with any other tracker, except that you aren't likely to run into a situation where there are forty seeders and no leechers. So just keep seeding and you'll get there. Link to comment Share on other sites More sharing options...
