tribaljet Posted December 18, 2009 Share Posted December 18, 2009 Hi there. I've been using the latest 1.16 version of bitcomet on a few systems, and in one in particular I noticed that the comment tab shows up blank even though it has comments. Also, on summary tab, when hovering the cursor over the download speed graphic, it stopped showing both my speed and peers speeds. It is a clean install but the weird thing is that on the other pcs they were upgraded and show neither one of these issues. OS: Win7 Ultimate x86 Antivirus/Firewall: Kaspersky Internet Security 2010 Connection: ADSL over router Suggestions as to why this might be happening are highly appreciated. Thanks Link to comment Share on other sites More sharing options...
kluelos Posted December 19, 2009 Share Posted December 19, 2009 Comments come from severs that are/were in the process of being moved. Link to comment Share on other sites More sharing options...
tribaljet Posted December 19, 2009 Author Share Posted December 19, 2009 So what does it mean? Replies will only be posted after a while? Link to comment Share on other sites More sharing options...
greywizard Posted December 19, 2009 Share Posted December 19, 2009 It means that when the server is down you can't access it. It's called causality. :P Link to comment Share on other sites More sharing options...
tribaljet Posted December 19, 2009 Author Share Posted December 19, 2009 Oh :) Sorry, wasn't following what he meant. I really begin to wonder if this latest version is as bug free as I expect. Besides the issues I mentioned in my previous post, now another machine is having a different issue, when I have a task selected it just doesn't update at all, unless I deselect or select another task. This is very annoying as the info on the columns is very useful. What really amazes me is that on both computers there was no change in hardware, software or config of any sort. Please, I'm really out of ideas of what this might be. As always, thanks in advance Link to comment Share on other sites More sharing options...
greywizard Posted December 19, 2009 Share Posted December 19, 2009 ... when I have a task selected it just doesn't update at all, unless I deselect or select another task. Does that happen when the window is maximized, as well? Link to comment Share on other sites More sharing options...
tribaljet Posted December 20, 2009 Author Share Posted December 20, 2009 I only use it maximized, but yes I have tried both and it behaves the same. Link to comment Share on other sites More sharing options...
tribaljet Posted December 20, 2009 Author Share Posted December 20, 2009 Sorry, I forgot to mention that the specs of the other machine are equal to the first, except that it's Win7 Home Premium, x86 as well, the rest is the same. Link to comment Share on other sites More sharing options...
greywizard Posted December 20, 2009 Share Posted December 20, 2009 Do the statistics update anywhere in one of these places (Task List, titlebar, floating window, Summary tab, Statistics tab)? Or it's all frozen? Link to comment Share on other sites More sharing options...
tribaljet Posted December 20, 2009 Author Share Posted December 20, 2009 It updates in the title bar, the summary tab, the statistics tab. It's the task list that's the problem since it only updates when selecting another task, then it updates once then freezes again. Link to comment Share on other sites More sharing options...
greywizard Posted December 21, 2009 Share Posted December 21, 2009 Yeah, this was an issue (but only with the window not-maximized) in one of the previous versions. Right now it looks fixed under XP at least. Try the current beta, see if it makes that go away. If not, report it back so that the team may take notice on that. Link to comment Share on other sites More sharing options...
