elshokali Posted December 25, 2009 Share Posted December 25, 2009 (edited) after making port forwarding i opened a "statistics" in bitcomet ver 1,16 i saw this massege " Overall Tasks: Total:8 / Running: 1 TCP Connections: Established: 43 [MAX:Unlimited] / Half-Open: 0 [MAX:18] LAN IP: WAN IP: 41.238.100.55 Listen Port of TCP: 24504 (Opened in Firewall/Router) Listen Port of UDP: 24504 (Opened in Firewall/Router) Windows Firewall: Added [TCP opened, UDP opened, TCP(ED2K) opened, UDP(ED2K) opened] NAT port mapping: wating for query IP address Overall Download Rate: 29 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task Overall Upload Rate: 10 kB/s [MAX:10] LT Seeding: 0 kB/s [MAX:3] All BT Upload Slots: 5 Free Phys Mem: 92.73 MB (Min to keep: 50 MB) Disk Cache Size: 48 MB (Min: 6 MB, Max: 50 MB) Disk Read Statistics: Request: 1779 (freq: 0.1/s), Actual Disk Read: 273 (freq: 0.0/s), Hit Ratio: 84.6% Disk Write Statistics: Request: 19545 (freq: 1.4/s), Actual Disk Write: 305 (freq: 0.0/s), Hit Ratio: 98.4% Total Downloaded: 8.92 GB Total Uploaded: 1.14 GB please is everything is OK??????????????? Edited December 25, 2009 by elshokali (see edit history) Link to comment Share on other sites More sharing options...
greywizard Posted December 25, 2009 Share Posted December 25, 2009 From the statistics it looks like you don't have a router, so... where did you do the port forwarding? You'd better read and post all the specs from here, if you need a 100% sure answer. Link to comment Share on other sites More sharing options...
Vasy Posted December 25, 2009 Share Posted December 25, 2009 Have you set a static IP too? Link to comment Share on other sites More sharing options...
elshokali Posted December 25, 2009 Author Share Posted December 25, 2009 (edited) :mellow: I have a router model " CNAD 804 NF Cnet and ADSL 512 speed and static IP Edited December 25, 2009 by elshokali (see edit history) Link to comment Share on other sites More sharing options...
greywizard Posted December 25, 2009 Share Posted December 25, 2009 Is your router in bridge mode? Link to comment Share on other sites More sharing options...
elshokali Posted December 25, 2009 Author Share Posted December 25, 2009 NO Link to comment Share on other sites More sharing options...
greywizard Posted December 25, 2009 Share Posted December 25, 2009 Well, then why doesn't BitComet report any LAN IP? What is the IP of the network card you use for connecting? Link to comment Share on other sites More sharing options...
