aileyus Posted January 4, 2010 Share Posted January 4, 2010 topic says it all. TIA Link to comment Share on other sites More sharing options...
kluelos Posted January 4, 2010 Share Posted January 4, 2010 I don't know, but I also don't know of any reason why it should not. Do you have some experience that the combination has unusual problems? Link to comment Share on other sites More sharing options...
aileyus Posted January 4, 2010 Author Share Posted January 4, 2010 Yes. It won't install on my Windows 7 Ultimate 64 bit. I run the install program and it does nothing. It installed and ran fine on 32 bit. Link to comment Share on other sites More sharing options...
aileyus Posted January 4, 2010 Author Share Posted January 4, 2010 I get the select language box and then after I select ok it just goes away and nothing happens. I open up task manager and see no evidence it's running. I open the start menu and don't see it as a program and it doesn't put an icon on my desktop. It just disappears. Link to comment Share on other sites More sharing options...
kluelos Posted January 4, 2010 Share Posted January 4, 2010 Have you checked the system and application error logs to see if a problem is being reported? You might also open Task Manager first, look at the processes, then try reinstalling while you watch. You should see the installer process start up, and then if it does die, you should be able to see that. It won't tell you why, but will confirm that it happens. You shouldn't actually have to install BC, just download a .zip version from the BC site and extract it to an appropriate directory, then run the program from there. You should be able to set all of your preferences including the language, from there. Link to comment Share on other sites More sharing options...
TheBritt2001 Posted January 10, 2010 Share Posted January 10, 2010 Actually, just to add on this. I have Windows 7 64Bit too (though it's Home Edition), which I recently installed. It was the only change I made between now and when I last used BitComet (which was on Vista 32bit). I tried to install BitComet and it did exactly the same thing as aileyus experienced. It would simply fail after the language selection. I checked on the Task Manager and yes it did indeed just drop off the list. So I went ahead and copied the zip files into a BitComet folder I made in Program Files and now it works fine. But yes, it won't install for some reason on Windows 7 64bit. Link to comment Share on other sites More sharing options...
aileyus Posted January 10, 2010 Author Share Posted January 10, 2010 Thanks. Now I know it's not just me. LOL Link to comment Share on other sites More sharing options...
greywizard Posted January 10, 2010 Share Posted January 10, 2010 I've installed just today BitComet on a Win 7 64bit system with no problems whatsoever (with both UAC activated and deactivated). So, obviously this is not a easy nut to crack since it doesn't happen on every system. It must be either a specific Windows setting or another application you're using which causes that. Link to comment Share on other sites More sharing options...
aileyus Posted January 12, 2010 Author Share Posted January 12, 2010 Hi Greywizard. This is a new machine with a fresh install of Windoze. I did have Registry Mechanic 9.0, AVG Free 9.0, and Office 2007 installed at the time. Could it be the virus checker needs to be disabled for the install? Thanks, Rick Link to comment Share on other sites More sharing options...
kluelos Posted January 12, 2010 Share Posted January 12, 2010 Bitcomet installation doesn't do anything at all that should bother an antivirus application, and AVG's never posed any problem on other OS's. Link to comment Share on other sites More sharing options...
hafiz1 Posted January 28, 2010 Share Posted January 28, 2010 Hi everyone.Iam here with the solution.I had the same problem that After the language box,installation won't.then I just go in properties of installation file and set it to run in compatibility with windows XP sp2.It worked like a charm.After installation I did same with bitcomet itself and now Iam using It without any problem.Hope that This will help. Regards Link to comment Share on other sites More sharing options...
jtettes Posted February 8, 2010 Share Posted February 8, 2010 (edited) Hey, I was having the same problem when installing BC on my PC with Windows 7 64bit Pro. What's nice about the Pro edition is...if you have any compatibilty issues with any programs you wish to run, Windows 7 Pro will run that program using whatever OS you want. This is why I bought the pro. I'm not sure if the Home Edition has this option?? But the problem is an easy fix...just as "hafiz1" already pointed out. When installing...save instead of run...go to where ever you saved the BC set up file...then right click on it...go to properties...click on compatibility, and then pick whatever OS with whatever service pack you want the program to run in. Very nice feature!!! Edited February 8, 2010 by jtettes (see edit history) Link to comment Share on other sites More sharing options...
DJ_Jingles Posted March 10, 2010 Share Posted March 10, 2010 Hi, Just to support the other guys. I had a clean install of Windows 7 and this was first thing I tried to install. Experienced the same issues when installing Bitcomet. Followed advice above and saved files etc etc. Worked perfectly. Thanks ! :) Link to comment Share on other sites More sharing options...
