dreamer88 Posted January 11, 2010 Share Posted January 11, 2010 Bitcomet version:1.17 Browser:Mozzila firefox Internet: broadband Problem: Program keeps shutting down every 5 mins. I have disabled autoshutdown but doesnt work. I recently downloaded 1.17 to solve problem but its still there. Please help! Link to comment Share on other sites More sharing options...
Vasy Posted January 11, 2010 Share Posted January 11, 2010 Hi! READ THIS BEFORE POSTING... I'm having a hard time understanding your post... The shutdown feature is mainly for shutting down your pc, not just BitComet, unless you set it to. What's the memory usage of BitComet when it crashes? How many tasks are you running? What Operating System do you have, and do you update it often? Have you tested your memory? (use memtest) What antivirus do you use? Link to comment Share on other sites More sharing options...
cassie Posted January 13, 2010 Share Posted January 13, 2010 I recently downloaded 1.17 to solve problem but its still there. Which version were you using before? Did you have the same problem with it? Link to comment Share on other sites More sharing options...
dreamer88 Posted January 13, 2010 Author Share Posted January 13, 2010 Yes I had the same problem. I overwrote the other version so I dont know which it is. But it is an older one. Link to comment Share on other sites More sharing options...
