Mov files, no sound
Iggycom
I have tried everything to get sound working on MOV files from my Canon Powershot. A couple of times it worked for a couple of minutes but then gone again. I have tried loading older versions as well as the latest. I have tried loading it with/without the Quicktime driver when installing. I used regedit to completely clear everything before installing different versions.
These are the audio specs.
Any help would be appreciated.
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 1mn 34s
Bit rate mode : Constant
Bit rate : 1 411.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 15.9 MiB (6%)
Encoded date : UTC 2010-01-20 20:57:09
Tagged date : UTC 2010-01-20 20:57:09
Have you tried QuickTimeAlternative? If that works we can clear out system and codec issues.
I am pretty surprised to see that it's using PCM instead of AAC encoding for audio, which is what Apple uses for everything including, by default, Quicktime. I wonder if using PCM instead is supported anywhere? You should probably ask somebody who knows more about this than I do, but that seems really odd to me. OTOH, maybe that's the whole problem?
I got it. They were all disabled. I was about to pull my hair out on this one. I can't imagine why they were disabled, when I loaded MPCStar it said RM and QT codecs installed.
Now my next mission is to find something good and easy to convert these files to a format that will play on my PopcornHour and Mvix Ultio. I'm dissapointed that neither will play them.
Thank You So Much
Edited by greywizard
Removed qutation (see edit history)
  • 2 months later...
How come mine one still didn't have sound?
Please advise... Thanks :)
Below is my ffdshow audio decoder configuration:
MP1,MP2 - libmad
AC3 - liba52
E-AC3 - disabled
MLP - disabled
DTS - libdts
AAC - libfaad2
Vorbis - Termor
AMR - libavcodec
LPCM - enabled
WMA 7 - disabled
WMA 8/9 - disabled
MS ADPCM - libavcodec
IMA ADPCM - libavcodec
Other ADPCM - libavcodec
Mulaw/Alaw - disabled
MS GSM - disabled
FLAC - disabled
True Audio - libavcodec
TrueSpeech - disabled
QDM2 - disabled
MACE3,MACE6 - disabled
Real Audio - disabled
IMC - disabled
ATRAC3 - disabled
Nellymoser - disabled
AVIS - disabled
Uncompressed - disabled
horng, why don't you make a new topic, and start all over again. Pretend that nobody knows what you're talking about unless you mention it. Because, basically, we don't, and it's ridiculous to try to pull it out of you bit by little bit. Explain carefully, and in necessary detail, what your problem is.
Sorry about annoying...
Before that I'm using old version Mpc Star to play RMVB movie. One day when I on my pc and watching movie suddenly the Mpc Star didn't have sound while I playing movie. I had try using RealOne Player to play other format and it works fine with sound. So I uninstall the old version and try install the lastest version and then restart pc but the problem still persist.
