2rrr Posted February 26, 2010 Share Posted February 26, 2010 (edited) i found that bitcomet 1.18 have high memory usage issue....even my download speed not more 100kB/s....even i off my utorrent and other program. at last when u on few hours...bitcomet memory usage for sure will increase 100MB++ ~ 200MB++.....i try another pc downloading aso have tis issue. may i know this issue is it resolve on version 1.19??? Pls advice. TQ. Edited February 26, 2010 by 2rrr (see edit history) Link to comment Share on other sites More sharing options...
2rrr Posted February 26, 2010 Author Share Posted February 26, 2010 after 1 day....i monitor memory issue again. Link to comment Share on other sites More sharing options...
kluelos Posted February 26, 2010 Share Posted February 26, 2010 Nope. It's not a problem. BitComet uses a lot of memory for cache to minimize disk writes. Nobody's going to try to fix it because it isn't broken. Using memory is not a problem. Memory is there to be used. Using memory and ... (something else happens because of it) might be a problem, but you said nothing about that. If simple memory usage bothers you, then you should probably stick with µtorrent. Link to comment Share on other sites More sharing options...
