Bookmarks no longer work - Help
My bookmarks stopped working and haven't been working for weeks.
If I click a bookmark that is on my bookmarks toolbar or my Bookmarks dropdown,
nothing happens. If I save a new bookmark, for example, www.yahoo.com, and then
try to access this new bookmark, (for example, entitled "fred")nothing happens.
I stay on the page that I was on. The new bookmarks shows in my bookmarks menu,
but clicking it does nothing. If I rest my cursor on the bookmark, the popup
shows the correct URL.
I'm on Cometbird 3.6.2. I've been using it for months now and love it.
They used to work. I have no idea why they stopped working.
All the bookmarks work fine if I click them in the Organize Bookmarks item (the Library).
One of your answers to someone about bookmarks says that bookmarks are stored here:
%appdata% in the CometNetwork/CometBird/Profiles/(you) directory under bookmarks.html
Under Profiles, my username is not listed (for example, my last name Smith), but instead
there is a folder called this: a05aoykp.default.
Under that is a bookmarks.html file with a last modified date of 8/8/2008.
The Profiles folder also contains a bookmarkbackups folder that contains a bookmarks.html file
with a date of 3/9/2010. and several .json files, for example, this one
bookmarks-04-07-2010.json
Can you tell me how to get my bookmarks working again?
Thank you.
