MadOmega Posted April 19, 2010 Share Posted April 19, 2010 In particular, if earlier versions worked for you, you can reinstall them and compare the working chain with the latest version's. before reading this, i took my brothers leptop(same model even OS-yes i bought one for my bro just like mine) got version 4.1 from his, unisntalled mine, deleted files from C:\Program Files\MpcStar and i still have this problem with the sound... he does not... i should switch em when hes sleeping... hehe... or maybe you could tell me what registries or "remaining files" i need to delete that might solve this. Thnaks Link to comment Share on other sites More sharing options...
MadOmega Posted April 19, 2010 Share Posted April 19, 2010 (edited) i want to add that i took the time to dezinstall mpcstar again, delete remaining file from Program Files/MpcStar, rebooted, opened regedit and manually removed every entry under the keyword "mpcstar", operation that took a long time (about 30mins) not even sure if it was supposed to delete everything but i did... i don't know if the problem was a busted registry or version 4.4 change something in the registry...but im sure the deletion of the registry helped so the problem was somewhere there well i'm just happy i got a working MpcStar again! :) Thanks for support! Edited April 19, 2010 by MadOmega (see edit history) Link to comment Share on other sites More sharing options...
danmah222 Posted July 24, 2010 Share Posted July 24, 2010 am using windows 7,,a month ago mpcstar behaved like this then updted to this bew versin yesterda still has no sound all players in my comp are playing well..pliz tell me the cause i prefer mpcstar to others.. Link to comment Share on other sites More sharing options...
Ferny_dx Posted September 9, 2010 Share Posted September 9, 2010 try playing a flash file (.swf) and close MPC star and then open your other file, it fixed my problem Link to comment Share on other sites More sharing options...
concept_39 Posted December 28, 2010 Share Posted December 28, 2010 after playing .swf file and my problem fixed. what's that all about. Link to comment Share on other sites More sharing options...
greywizard Posted December 29, 2010 Share Posted December 29, 2010 Lucy, perhaps the team might want to look into this. This info may help trap this bug. Link to comment Share on other sites More sharing options...
Lucy26 Posted December 29, 2010 Share Posted December 29, 2010 Thank you for reporting problems, the development team will work on them. Thanks Wiz, for notifying me. :) Link to comment Share on other sites More sharing options...
