HELP created subtitle not working properly
T_Azam
Hi!
I recently worked on a movie subtitle using DIV X LAND media sub-titler,my movie is in Divx avi format and the video fps=23.967.I saved the file as .SRT format,but the thing isn't working properly,I have to adjust the subtitle setting panel of MPC star player to -34 to view the subtitle at the bottom of the screen.I want to make a DVD of the movie with the subtitle,what should I do to have the subtitle to be seen at the bottom without doing any thing.
Need guidance.
thanks.
Edited by T_Azam (see edit history)
