Kagenestir Posted May 31, 2010 Share Posted May 31, 2010 i'm using bitcomet version 1.21, With DSL connection. I'm not using a router and my antivirus is kapsersky. my speed test was download 36.35mb/s and Upload .49mb/s, ping 15 ms. I tried using the bitcomet speed guide but it didn't help. My upload speed usually doesn't exceed 1 kb's on torrents and alot of the time it stays at 0. My connection is capable of supporting a higher speed so i was wondering if you could help me get it higher. My setting are unlimited download and upload. Link to comment Share on other sites More sharing options...
kluelos Posted May 31, 2010 Share Posted May 31, 2010 The speed guide tells you that you shouldn't use an "unlimited" setting for your upload speed, so it seems like you didn't read it too carefully. You might try looking at it again. Most of what we'll tell you is already in there. DId you try downloading the Open Office torrent or one of the Linux distros? What were the results? Link to comment Share on other sites More sharing options...
