Downloading problem
Hi...
I am using the product since a long. I really enjoy to utilizing it, for downloading informative stuff. But since few days, I have a problem. Problem is that there is no downloading process work. I uninstall it and newly download it. But its remain occur. Kindly tell me how it can repair? I am sending snap from my desktop, from where you may pick the problem. I am waiting for your reply.
Regards
Edited by luv connecting... (see edit history)
Please make sure to post in the proper forum... this one is just for introducing yourself.
Whenever you have a question, you first have to provide what we consider the Essentials and be able to include the maximum amount of detailed information (speed test results, the settings that you're using, which Tutorial/s you have followed, etc.) possible - the more, the better.
You may also want to read our very easy-to-follow tutorial regarding posting screenshots here.
Regards. :)
*topic moved to BitComet General Discussion*
