pegasus1666 Posted September 14, 2010 Share Posted September 14, 2010 Hi!, i just wonder where the feature went that allowed you to choose what file(s) to download first (you could for example choose file 1 got high priority and another to have 50% priority and some to have low)or is it still there but you have to fix anything in the option? Link to comment Share on other sites More sharing options...
greywizard Posted September 14, 2010 Share Posted September 14, 2010 Are you talking about Download Order or what? Link to comment Share on other sites More sharing options...
pegasus1666 Posted September 15, 2010 Author Share Posted September 15, 2010 Aye i think that's the one my bitcomet got updated and it was gone, it was down next to the comments/peers/logs/trackers etc etc Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 15, 2010 Share Posted September 15, 2010 Please understand that by changing these settings you will make the overall download less efficient. Your best to leave all files on "normal". Link to comment Share on other sites More sharing options...
greywizard Posted September 15, 2010 Share Posted September 15, 2010 I think you're speaking about the Files tab in the Detailed Info Pane. If that's the case, you can make any of the tabs visible by right-clicking on any of the tabs and putting a checkmark in front of the ones you want visible. Link to comment Share on other sites More sharing options...
kluelos Posted September 15, 2010 Share Posted September 15, 2010 The update just fiddled with the layout. It did this to me, too. I thought it might have been to point out the existence of some new tab choices, but it's easy enough to put things back, as Wiz points out. Link to comment Share on other sites More sharing options...
pegasus1666 Posted September 16, 2010 Author Share Posted September 16, 2010 Thanks for all the help guys, thanks :) Link to comment Share on other sites More sharing options...
