ThoalfeqarAli Posted September 16, 2010 Share Posted September 16, 2010 hi i have comet id (NEW) but y the Points Remain Zero and the Score up to (95) like the Photos (why) and how 1- up the (EXP)(0%) 2- up the level THANKS Link to comment Share on other sites More sharing options...
greywizard Posted September 16, 2010 Share Posted September 16, 2010 A score of 100 won't bring you 100%. You can view more info on the Comet ID ranking system in this Wiki topic. Link to comment Share on other sites More sharing options...
ThoalfeqarAli Posted September 16, 2010 Author Share Posted September 16, 2010 ok but her see BC Score = Points from online time + Points from uploaded Bytes. 1.Being online can generate 2 points per hour, with a limited maximum of 20 points, per day. 2.Uploading files continually, via BitTorrent protocol, can generate 1 point per 10MB, with a limited maximum of 100 points, per day. 3.Downloading files, via BitTorrent protocol, doesn't affect the Score. The same applies to HTTP and FTP protocol. 4.The Score will be refreshed every 24 hours. to up my points and i online (6-8)hours on the day and i uploading (98)mb of torrent but the points(EXP) Remained zero Why Thanks Link to comment Share on other sites More sharing options...
greywizard Posted September 17, 2010 Share Posted September 17, 2010 The points are found in the score not in the percentage. The percentage represents the path from one rank to the next and therefore it goes up much more slowly. Link to comment Share on other sites More sharing options...
Lucy26 Posted September 17, 2010 Share Posted September 17, 2010 The EXP was not correctly displayed, the team will fix it soon. By the way, EXP doesn't equal to score, as you have 95 points, you will need another 205 to upgrade, EXP tells you the percentage of points you earned in this level. For example, you have 95 points now, 95/300=31.8%, so your EXP should be 31% or 32%, definitely not 0%, but not 95% either. Link to comment Share on other sites More sharing options...
ThoalfeqarAli Posted September 17, 2010 Author Share Posted September 17, 2010 yas i mean thereis aprooblem in the (EXP) i will Understand How works the points and the score Thanks Link to comment Share on other sites More sharing options...
