kluelos Posted September 17, 2010 Share Posted September 17, 2010 I had updated my XP SP3 system to BitComet 1.23, then noticed problems loading most web sites in FireFox. (I run BitComet almost constantly.) Sites never seemed to load but never timed out either. If I let them run they load eventually, but this can take a hour or more. I noticed that BitComet's tray balloon said it was uploading at 24 KB/s which is the extreme limit of my connection. I opened BitComet, and the title bar confirmed 24 KB/s. My global maximum upload speed is set to 20 KB/s, which I reconfirmed. (LT seeding is disabled, though that should not be relevant.) Lowering the global maximum upload speed made no difference. 1.23 is blowing right through the limit I set. I've stepped back to 1.22 which has apparently resolved the issue. Link to comment Share on other sites More sharing options...
greywizard Posted September 17, 2010 Share Posted September 17, 2010 This was, more or less, one of the issues I've reported in one of the betas for v.1.23. I hope the team is working on that and that they will, once and for all, make the client NEVER go above the set upload limit. While more robust connections can deal with that "surplus" over the set limit, it really brings down to their knees the slower ones. Link to comment Share on other sites More sharing options...
Lucy26 Posted September 20, 2010 Share Posted September 20, 2010 Yes Wiz has reported this problem before, however the team could not reproduce it, and we did not see any problem from the bitcomet.xml sent by Wiz. :unsure: Link to comment Share on other sites More sharing options...
kluelos Posted September 20, 2010 Author Share Posted September 20, 2010 It's a crippling problem. You can't do anything else, internet-wise, with BC taking over all of the bandwidth. While it could be a problem with the value written into the .xml file, it could equally be a code problem with reading the value or respecting it once it's read, and those wouldn't show up in the .xml file. Link to comment Share on other sites More sharing options...
kluelos Posted September 24, 2010 Author Share Posted September 24, 2010 I have found 1.22 also ignoring the set limit, although not "pegging the meter" at maximum, so 1.23 is just worse and not the origin of the problem. I'm having to choose between running BitComet or doing anything else on the internet. That isn't good. Link to comment Share on other sites More sharing options...
kluelos Posted September 24, 2010 Author Share Posted September 24, 2010 Add 1.21 to the list. Now trying 1.20 Link to comment Share on other sites More sharing options...
kluelos Posted September 25, 2010 Author Share Posted September 25, 2010 And a fail there. Back to 1.17. Downgrading to 1.17 will mess you up, because you're going backwards across the transition to storing things in %appdata% instead of the program directory. 1.17 is where I came into this party, finally deciding to move on from 0.70 for most of my torrenting at the time it was released. I feel like I'm being chased back to 0.70. 1.20's transgressions weren't so bad, which is perhaps why this hasn't been reported before, but if I set a global max upload limit of 20 KB/s, then BitComet needs to be uploading at 20 KB/s or less, not skip up to 21, or 24 when it feels like it. I've been loading the version, setting it to run, and watching for this behavior mostly with the systray balloon, and when I see it slip above its limit, verifying this with the full application. This behavior is progressively worse -- happens more frequently and exceeds the limit by a wider margin more consistently -- with later versions. Whoops, no, here's 1.17 uploading at a steady 21 KB/s when its upload limit is set at 20. Maybe I will have to go all the way back to 0.70 Link to comment Share on other sites More sharing options...
Lucy26 Posted September 26, 2010 Share Posted September 26, 2010 I see here. Thank you kluelos, I'll report to the team and see if they can fix the problem. ;) Link to comment Share on other sites More sharing options...
kluelos Posted September 26, 2010 Author Share Posted September 26, 2010 Thanks, Lucy. BTW, 1.10 and 1.00 have the same issue, so I'm back to 0.70 as my regular client. The issue, specifically, is that I set a global maximum upload speed limit of 20 KB/s, but these clients will exceed that for substantial time periods -- usually, popping up to 21 KB/s and sustaining that. They don't greatly exceed that, so they don't completely shut you down like 1.23 does, but they're still not respecting the limit. Link to comment Share on other sites More sharing options...
Lucy26 Posted September 27, 2010 Share Posted September 27, 2010 Thank you testing the previous versions, kluelos. The team will work on the problem. =) Link to comment Share on other sites More sharing options...
alaa777 Posted October 8, 2010 Share Posted October 8, 2010 (edited) http://www.cometforums.com/topic/12795286-download-limit/page__p__55183__fromsearch__1entry55183 so the bug reproduced finally :D Edited October 8, 2010 by alaa777 (see edit history) Link to comment Share on other sites More sharing options...
kluelos Posted October 9, 2010 Author Share Posted October 9, 2010 No, sorry, that's a different issue entirely. Link to comment Share on other sites More sharing options...
