perrochafa Posted September 26, 2010 Share Posted September 26, 2010 how can i reset bitcomet options to default? Link to comment Share on other sites More sharing options...
Lucy26 Posted September 26, 2010 Share Posted September 26, 2010 Firstly exit BitComet, then delete your bitcomet.xml, which can be found here: Vista/Win7 : %SystemDrive% \Users\Username\AppData\Roaming\BitComet XP : %SystemDrive% \Documents and Settings\Username\Application Data\BitComet When you open your BitComet again, the options will be set as default. Link to comment Share on other sites More sharing options...
perrochafa Posted September 27, 2010 Author Share Posted September 27, 2010 thank you Link to comment Share on other sites More sharing options...
