tpznorl123 Posted October 26, 2010 Share Posted October 26, 2010 (edited) Hello, So I am new to this. And need step by step HELP!! Edited October 26, 2010 by tpznorl123 (see edit history) Link to comment Share on other sites More sharing options...
tpznorl123 Posted October 26, 2010 Author Share Posted October 26, 2010 Sorry I should of given more info...I am trying to figure out how to download movies, then transfer to USB. HELP Thanks. Link to comment Share on other sites More sharing options...
kluelos Posted October 26, 2010 Share Posted October 26, 2010 Look in the Guides and Tutorials forum. If you pay for software, then you may expect handholding and step-by-step instructions. BitComet and bittorrent are not those things. You did not pay for the software, you did not pay for any support. Therefore, you are expected and required to use a lot more personal initiative than you have shown so far: to figure things out for yourself; to try things; to learn by trial and error; to teach yourself and make sense of what you have learned. There will be very little basic instruction to be had, and where there is, you will need to learn to seek it out for yourself rather than having to be told to go look in a clearly labeled forum that was plainly apparent. This level of helplessness just isn't going to be sufficient. If you don't like this or aren't willing or able to do it, then you should not attempt to use free software. Link to comment Share on other sites More sharing options...
greywizard Posted October 28, 2010 Share Posted October 28, 2010 You can start reading from the BitComet Wiki, beginning with the Tutorial section topics. Link to comment Share on other sites More sharing options...
khota33 Posted November 12, 2010 Share Posted November 12, 2010 contact me at khota33. would be pleased to help. Link to comment Share on other sites More sharing options...
