Dasmandar Posted October 31, 2010 Share Posted October 31, 2010 Do anyone has the same problem as I?When I open my bitcomet,and I play media files my media will sort of lag for 3 secs and continue sort of like my whole come freezes there and then it resumes back 2-3 sec later.It happen once every 2-5 min when I turn on my bitcomet and play media files. This only happen when i play media files and turning on the bitcomet at the same time. Link to comment Share on other sites More sharing options...
kluelos Posted October 31, 2010 Share Posted October 31, 2010 The pauses are due to disk activity when BitComet writes its cached material. That can interrupt the reading of the media file. This seems to affect some players more than others, and can be ameliorated by some system and player settings. Make sure your drives are set to use DMA if available. If you can, save your downloads to a different physical drive than the one you're playing media from. Link to comment Share on other sites More sharing options...
Dasmandar Posted November 1, 2010 Author Share Posted November 1, 2010 Okay but that only explains for the movies and tv series since they share the same hard disk. But for music I'm using another totally different drive. To put it more clearly C-music+OS D-Bitcomet dl drive+movies+tv series. As for the DMA setting where do i set it? Link to comment Share on other sites More sharing options...
kluelos Posted November 1, 2010 Share Posted November 1, 2010 DMA is set at your disk controllers, in the Device Manager. Link to comment Share on other sites More sharing options...
