MPCSTAR 4.9 MKV PROBLEMS
divadmil
I am currently using my dell studio to watch harry potter (MKV format)
i have no problem playing it on my dekstop...
i tried to play on my laptop ...
it wrote "NOW PLAYING"
but the sec is not moving , meaning like 00:00 / 2:22:00
i press (SPACE) to play...
it is playing but the video is not moving...
i try to fast forward to any sec ... then i press play again , nothing happens :(
VIDEO INFORMATION : Harry Potter (MKV FORMAT)
suspect : is it screen size problems?
i have no problem playing mp4 format on my laptop...
MY BRO ARE USING DELL STUDIO and his screen size is slighty bigger than usual laptop.
mine is just a normal laptop screen size.
HELP~~~
i can play 720p , just cant play 1080p.
cause when you PLAY/STOP.
there will write PLAY/STOP.
PLAYING <-- wrote there...
but not moving , cause starting is 00:00 > 00:01 right? it not moving the sec.
i think is cant play la.
but i don't receive any error.
my bro dell laptop the screen size is larger than mine , and i have no problems playing on dekstop.
i guess my laptop screen is too small to play 1080p video? :(
screensize should not be the problem, I can run 1080p on a smaller screen aswell.
After a bit of searching I found that your laptop has a some good hardware and should be fine with 1080p movies.
Maybe you can try and get another 1080p movie and see if that one works/
i think that way too...
haihz...all the codec i have...
and my laptop is not old enough should be able to support , i just cant play it.
when i play the HARRY POTTER no error message come out.
it is PLAYING , but just not moving, the screen , the screen picture just STONE there.
