Ayuda: velocidad descarga - vip
:D Buenas noches.
:blink: Acabo de ingresar y ya tengo un par de preguntas que realizar.
1ªpregunta: alguien podria indicarme como hacer para mejorar la velocidad de la descargar de Bitcomet?
2ªpregunta: hay alguna manera sin tener los 80mil puntos de probar la version vip de Bitcomet?
Aqui dejo los datos esenciales:
-version 1.25
-conexion adsl
-uso wifi
-Xp
-velocidad de bajada 4995 y de subida 383 ping 53ms
Aqui tienen creo que todo lo que piden como minimo.
Un saludo.
Gracias.
Leyendo otros post, me gustaria por favor que me indicarais si podeis que configuracion seria la mas adecuada para mejorar la descarga etc. He leido que tependiendo de tu velocidad debes ponerlo a un 70% (o algo asi) si pudieseis explicarme eso lo agradeceria.
un saludo B)
:D Buenas noches.
-version 1.25
-conexion adsl
-uso wifi
-Xp
Un saludo.
Gracias.
Good evening.
I just logged in & I already have a few questions.
1st question: Could somebody show me how to increase the speed at which Bitcomet downloads?
2nd question: Is there any way to test out the VIP BitComet version without having the 80 thousand points?
Here are the details:
-using version 1.25
-dsl connection
-using wifi
-Windows XP
-Downloading at 4995 and uploading 383 ping 53ms
I think that is all you need from me.
un saludo B)
I was reading other posts & I would like somebody to show me what would be the best configuration for me to have as to better my downloads etc. I read that depending on your internet speed you can set it at 70% (or something like that) if you can explain this to me I'd really appreciate it.
Cheers.
Hi,
we apologize for delay in getting your topic translated.
As for the vip service, it is very new and for an inexperienced user, I'd like to see you learn more about torrents and how they work before you consider using a service like this, that way you'll know what to expect and when using it would give you the benefits you desire.
for adjusting your settings, we have guides posted in the forum that explain this far better then I could in a single forum post. This topic would be a good place to begin...
http://www.cometforums.com/topic/3646-guia-de-ajustes-para-bitcomet-070-por-bitdave/
