withers1945 Posted January 18, 2011 Share Posted January 18, 2011 I have recently downloaded a number of movies and would like to add some comments to the Torrents.I have searched numerous guides, FAQ's, forums etc without success. How is it done? Thanks Link to comment Share on other sites More sharing options...
Vasy Posted January 18, 2011 Share Posted January 18, 2011 You first need to sign up here. Then go to the comments section of each torrent in BC and make sure you write the correct verification code. Link to comment Share on other sites More sharing options...
withers1945 Posted January 18, 2011 Author Share Posted January 18, 2011 Thanks Vasy, I followed the link to CometID, entered the req info and are now logged in. I can find no reference to a verification code.I have been back to my Bitcomet download screen, selected a completed download, highlighted the comment link but can still not enter any text. Link to comment Share on other sites More sharing options...
voguegucci Posted January 18, 2011 Share Posted January 18, 2011 I can find no reference to a verification code.I have been back to my Bitcomet download screen Link to comment Share on other sites More sharing options...
Vasy Posted January 18, 2011 Share Posted January 18, 2011 Now, you post screenshots of the comments tab, after scrolling all the way to the bottom. You also need to log in in the BC interface. Link to comment Share on other sites More sharing options...
withers1945 Posted January 19, 2011 Author Share Posted January 19, 2011 Thanks Vasy, After seeing the screenshot on your latest reply I realise that Bitcomet version 1.07, that I have, does not have that window. I have now upgraded to version 1.25 and have now successfully posted my first comment. Problem solved. Link to comment Share on other sites More sharing options...
ericross Posted January 19, 2011 Share Posted January 19, 2011 I have bitcomet v1.20 installed in windows 7 but the programme keeps coming up with programme not responding, is there anything one can do to sort out this problem ? Link to comment Share on other sites More sharing options...
kluelos Posted January 19, 2011 Share Posted January 19, 2011 ericross, probably, but first, it's confusing and a bit ill-mannered to jump into the middle of someone else's thread to try to hijack it for your own issues. Start your own thread. Second, you didn't provide anything like enough information to help you. Most of it should be obvious, but just in case, there's a sticky topic titled, "READ BEFORE POSTING" that you should read, before posting your question, in its own new thread. Link to comment Share on other sites More sharing options...
