BitComet 1.26 Latest Problem
Hi guys
Help guys
I have this Specification
Win XP Media Center
Thomson 585g Adsl modem
My issue is I am downloading torrent file my speed is going up to 1.5 MB to 8 MB until 30 – 45 minute the bit comet mark Red X on my files then I have to bush play button to resume the download it's stay to 200 KB for 1 hours then going mad up to 8 MB then Stop X again I use almost all bit comet version but I have the same problem not mentioning the freezing of my PC.
P.S I make many formats downloading fresh copy of bitcomet but the problem still here
My pc is:
Core 2 duo 2.8
2 GB DDR2 Ram
1 GB Nvidia g,force 9500 GT
1.5 TB HDD
Win XP SP2
Latest driver update
Thank you
Post the results of a test speed (e.g. http://speedtest.net).
Also what is your global upload speed cap in BitComet?
What type of port forwarding are you using (automatic or manual)?
As for the red cross, whenever that happens make sure that you have the Summary tab selected.
Both by looking at the Summary tab (upper right side) or by hovering your mouse over the red X icon you should see a message static what is the cause of the error. We need to know that.
Is the download location on an internal or external/removable drive?
