ossama2007 Posted February 26, 2011 Share Posted February 26, 2011 hi mpcstar 5.0 does not response with mpg file that decoded with mpeg 2.0 installed codec klite last version please help Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted February 26, 2011 Share Posted February 26, 2011 Because your message doesn't specify, I'm unclear as to which you are reporting. Are you trying to open mpcstar by executing the mpg file? Or are you trying to Open the mpg file from within mpcstar? The former would be a problem with windows file associations, not mpcstar. The latter could be a problem with mpcstar, but we'd need more details on the file/s your trying to open. Link to comment Share on other sites More sharing options...
ossama2007 Posted February 27, 2011 Author Share Posted February 27, 2011 hi of course i'm trying to Open the mpg file from within mpcstar mpg file is file video recorded from satellite card with program Mytheatre which produce mpg file (Video: MPEG2 Video 720x576 (4:3) 25.00fps 2369Kbps [Video] Audio: MPEG Audio 48000Hz stereo 128Kbps [Audio]) mpcstar 4.9 work fine but when i update to mpcstar 5.0 it hang with no responce i thought the problem with ffdshow video decoder but it's not. so can you help Link to comment Share on other sites More sharing options...
kluelos Posted February 27, 2011 Share Posted February 27, 2011 Does MPCStar lock up? If it does not, you should look under the FILE menu, at the FILE INFO item, to see what MPCStar is using to handle the file and what it thinks the streams are. This should at least provide useful information. Link to comment Share on other sites More sharing options...
johjue Posted February 28, 2011 Share Posted February 28, 2011 hi mpcstar 5.0 does not response with mpg file that decoded with mpeg 2.0 installed codec klite last version please help Having the same problem with .VOB files not playing and freezing mpcstar since upgrading to 5.0. Tried uninstalling, re-downloaded 5.0, and reinstalled. Problem persists. I have gone back to 4.9 and all is well. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted February 28, 2011 Share Posted February 28, 2011 a vob file is usually mpeg2 also, so this should be helpful information for development. Link to comment Share on other sites More sharing options...
ossama2007 Posted February 28, 2011 Author Share Posted February 28, 2011 hi actually mpcstar write playing but stream not moving a bit . mpcstar not lock up this info from playing info file stream is (Video: MPEG2 Video 720x576 (4:3) 25.00fps 2582Kbps [Video - MPEG2, Spatially Scalable Profile, Level 8, 720x576, 25.000 fps, 2582.4 kbit/s (0000,e0,00)] Audio: MPEG Audio 48000Hz stereo 128Kbps [Audio - MPEG1 - Layer 2, 48.0 kHz, 2 chn, 128.0 kbit/s (0000,c0,00)] Subtitle [No subtitles]) OUT] Video - MPEG2, Spatially Scalable Profile, Level 8, 720x576, 25.000 fps, 2582.4 kbit/s (0000,e0,00) - Connected to: CLSID: {39F498AF-1A09-4275-B193-673B0BA3D478} Filter: MPEG-2 Video Decoder Pin: Video - Connection media type: Video: MPEG2 Video 720x576 (4:3) 25.00fps 2582Kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_MPEG2_VIDEO {E06D8026-DB46-11CF-B4D1-00805F6CBBEA} formattype: FORMAT_MPEG2_VIDEO {E06D80E3-DB46-11CF-B4D1-00805F6CBBEA} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 218 VIDEOINFOHEADER: rcSource: (0,0)-(0,0) rcTarget: (0,0)-(0,0) dwBitRate: 2582400 dwBitErrorRate: 0 AvgTimePerFrame: 400000 VIDEOINFOHEADER2: dwInterlaceFlags: 0x00000000 dwCopyProtectFlags: 0x00000000 dwPictAspectRatioX: 4 dwPictAspectRatioY: 3 dwControlFlags: 0x00000000 dwReserved2: 0x00000000 MPEG2VIDEOINFO: dwStartTimeCode: 0 cbSequenceHeader: 86 dwProfile: 0x00000004 dwLevel: 0x00000008 dwFlags: 0x00000000 BITMAPINFOHEADER: biSize: 40 biWidth: 720 biHeight: 576 biPlanes: 0 biBitCount: 0 biCompression: 0 biSizeImage: 0 biXPelsPerMeter: 0 biYPelsPerMeter: 0 biClrUsed: 0 biClrImportant: 0 pbFormat: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020: 80 67 27 00 00 00 00 00 80 1a 06 00 00 00 00 00 €g'.....€....... 0030: 00 00 00 00 00 00 00 00 04 00 00 00 03 00 00 00 ................ 0040: 00 00 00 00 00 00 00 00 28 00 00 00 d0 02 00 00 ........(...Ð... 0050: 40 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 @............... 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070: 00 00 00 00 56 00 00 00 04 00 00 00 08 00 00 00 ....V........... 0080: 00 00 00 00|00 00 01 b3 2d 02 40 23 06 4e 23 71 .......³-.@#.N#q 0090: 10 11 11 12 12 12 13 13 13 13 14 14 14 14 14 15 ................ 00a0: 15 15 15 15 15 16 16 16 16 16 16 16 17 17 17 17 ................ 00b0: 17 17 17 17 18 18 18 19 18 18 18 19 1a 1a 1a 1a ................ 00c0: 19 1b 1b 1b 1b 1b 1c 1c 1c 1c 1e 1e 1e 1f 1f 21 ...............! 00d0: 00 00 01 b5 14 82 00 01 00 00 ...µ.‚.... - Enumerated media type 0: Set as the current media type [OUT] Audio - MPEG1 - Layer 2, 48.0 kHz, 2 chn, 128.0 kbit/s (0000,c0,00) - Connected to: CLSID: {3D446B6F-71DE-4437-BE15-8CE47174340F} Filter: MPEG-1 Audio Decoder Pin: In - Connection media type: Audio: MPEG Audio 48000Hz stereo 128Kbps AM_MEDIA_TYPE: majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71} subtype: MEDIASUBTYPE_MPEG1AudioPayload {00000050-0000-0010-8000-00AA00389B71} formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 40 WAVEFORMATEX: wFormatTag: 0x0050 nChannels: 2 nSamplesPerSec: 48000 nAvgBytesPerSec: 16000 nBlockAlign: 384 wBitsPerSample: 0 cbSize: 22 (extra bytes) pbFormat: 0000: 50 00 02 00 80 bb 00 00 80 3e 00 00 80 01 00 00 P...€»..€>..€... 0010: 16 00|02 00 00 f4 01 00 01 00 01 00 01 00 1e 00 .....ô.......... 0020: 00 00 00 00 00 00 00 00 ........ - Enumerated media type 0: Set as the current media type thanks Link to comment Share on other sites More sharing options...
ossama2007 Posted March 5, 2011 Author Share Posted March 5, 2011 Hi no one reply me why? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted March 5, 2011 Share Posted March 5, 2011 Hi, If version 5.0 is unable to play your mpeg2 video, then I suggest you revert back to the previous version. If the problem is with mpcstar itself, then it's development team will need to address the issue with a product update. I cannot say how long that will take, but it will be announced when one is available. Link to comment Share on other sites More sharing options...
ossama2007 Posted March 6, 2011 Author Share Posted March 6, 2011 thanks for reply Link to comment Share on other sites More sharing options...
Lucy26 Posted March 7, 2011 Share Posted March 7, 2011 Hi ossama2007, we could not reproduce the problem, does your MPCStar 5.0 has problem when playing all your mpeg 2 files? If you have the source of the file, can you please send it to me? So the development team can test it. Thank you. :) Link to comment Share on other sites More sharing options...
ossama2007 Posted March 9, 2011 Author Share Posted March 9, 2011 Hi ossama2007, we could not reproduce the problem, does your MPCStar 5.0 has problem when playing all your mpeg 2 files? If you have the source of the file, can you please send it to me? So the development team can test it. Thank you. :) here you are Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted March 9, 2011 Share Posted March 9, 2011 ossama2007, If you intended to post a link, or a file attachment to this post, it didn't work. Please either upload a sample of the video (if it's a small file), or provide us a link to where we can get it to test. If the file is relatively small, say 20MB or less, then you can upload it to a site like Fileden.com, badongo.com, rapidshare.com, megaupload.com, or other. If it's 2mb or less you can upload it direct to this forum. Note that most torrents contain a very small "sample" of the video content, so you won't have to edit the video or upload a very large file. Link to comment Share on other sites More sharing options...
ossama2007 Posted March 12, 2011 Author Share Posted March 12, 2011 hi here you are http://www.megaupload.com/?d=QI0AOPW9 thanks again Link to comment Share on other sites More sharing options...
kluelos Posted March 12, 2011 Share Posted March 12, 2011 I confirm this. VLC 1.17 will play this file. MPCStar 5.0 will not, and it caused MPCStar to crash. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted March 13, 2011 Share Posted March 13, 2011 I can also confirm that it works with Media Player Classic (MPC-HC 1.3.1976.0) Thanks for providing this. That should be all the development team needs to fix the problem. For the meantime, I can only suggest you revert to a prior version and check the release notes when a new version is released. Link to comment Share on other sites More sharing options...
Lucy26 Posted March 14, 2011 Share Posted March 14, 2011 Thank you for the link, ossama2007, the development team will test the problem. :) Link to comment Share on other sites More sharing options...
ossama2007 Posted April 29, 2011 Author Share Posted April 29, 2011 hi The Same problem with mpcstar 5.1 Thnks Link to comment Share on other sites More sharing options...
element81 Posted April 30, 2011 Share Posted April 30, 2011 cool my first post.. anyways, this problem occurs on me too.. playing mpg made from Corel videostudio 12 below is the file info from mpcstar: Video: MPEG2 Video 720x480 (4:3) 29.97fps 8000Kbps [Video - MPEG2, Spatially Scalable Profile, Level 8, 720x480, 29.970 fps, 8000.0 kbit/s (0000,e0,00)] Audio: Dolby AC3 48000Hz 6ch 384Kbps [Audio - Dolby Digital, 48.0 kHz, 6 chn, 384.0 kbit/s (0000,bd,80)] Subtitle [No subtitles] Link to comment Share on other sites More sharing options...
vision25th Posted May 2, 2011 Share Posted May 2, 2011 Same Problem with MPCSTAR5.0 and 5.1 version4.9 works fine ^-^ thanks for MPCstar ^-^ best player ever hope for a fix on this 5.1skin looks good^-^ Link to comment Share on other sites More sharing options...
zodiac Posted May 12, 2011 Share Posted May 12, 2011 Hi everyone.I am having problem with playing any file of the following format: Video: MPEG4 Video 720x576 29.97fps 1199Kbps [Output 0] Audio: AAC 0Hz 0ch [Output 1]When I am playing the same file in avi format then there is no problem. After I have converted the avi to MP4 with a program called emicsoft video converter, the mpc star refuses to play the file. Anyone who has a idea about the mentioned problem?? I would really appreciate some help. Regards Mike from Sweden Link to comment Share on other sites More sharing options...
kluelos Posted May 12, 2011 Share Posted May 12, 2011 Sure sounds like the transcode messed up the file. Are you able to play the output with, say, VLC or anything else? Link to comment Share on other sites More sharing options...
zodiac Posted May 13, 2011 Share Posted May 13, 2011 Yes I am, even with the media player and the player within the media center that comes with the Windows7 Ultimate. I downloaded and installed the previous version of MPC player 4.9 to see if there is a difference, well the older one works like a swiss watch. That fact really confuses me, shouldn't newer versions be better than the older ones? Link to comment Share on other sites More sharing options...
kluelos Posted May 13, 2011 Share Posted May 13, 2011 Ok, well, that would have been a very good thing to have said in the first place, rather than make us ask you for it. So, time wasted because you didn't. Hopefully the developers will have this called to their attention. Link to comment Share on other sites More sharing options...
zerojinn Posted May 17, 2011 Share Posted May 17, 2011 Thank you for your reports, they will be forwarded to the development team. Our development team is working on this issue at the moment, but we are not able to reproduce the error yet. We will keep trying, once this error is fixed, you will know from the changelog of a future version. Link to comment Share on other sites More sharing options...
