vesnor Posted February 28, 2011 Share Posted February 28, 2011 My mpcstar player doesent load the subtitles when I start it up. If i right click and set the subtitles to english or whatever it works fine, but before i didnt need to do this with all the files only a few who didnt have preset subtitles. Can somebody tell me how to fix it please. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted March 1, 2011 Share Posted March 1, 2011 I'm not sure what your meaning by "preset subtiles". Subtitles are either hardcoded (which cannot be disabled), External (separate file), or some more advanced video containers can have multiple audio/subtitles and other information encoded. Also, since software versions change, you really should ask about your specific version so the person replying doesn't have to offer instructions multiple times for potentially dozens (or more) software versions. Link to comment Share on other sites More sharing options...
vesnor Posted March 1, 2011 Author Share Posted March 1, 2011 With preset i mean that the subtitles comes on when i start the file. I usually use MKV files, I dont know if those use external or are one of those advanced video containers. I have the 5.0 version of mpcstar player. Sorry for the bad explenation in the first post. Link to comment Share on other sites More sharing options...
kluelos Posted March 1, 2011 Share Posted March 1, 2011 You should look in the options under "Play", to assure that "Enable Subtitle Display" is checked. Link to comment Share on other sites More sharing options...
vesnor Posted March 1, 2011 Author Share Posted March 1, 2011 Already done it :) Link to comment Share on other sites More sharing options...
kluelos Posted March 1, 2011 Share Posted March 1, 2011 When you play a movie with subtitles, what options do you see available in the Subtitles menu? Do you see activve options that are normally greyed-out in movies without subtitles? Link to comment Share on other sites More sharing options...
vesnor Posted March 3, 2011 Author Share Posted March 3, 2011 Yeah I can use all the options under subtitles. if i select english the subtitles comes up like normal, but before i didnt have to do that. the subtitles came on by it self when i opened the movie. Link to comment Share on other sites More sharing options...
kluelos Posted March 4, 2011 Share Posted March 4, 2011 Well, it looks like the behavior may have changed to accommodate those who don't want any subtitles to come up unless specifically asked for. This could be done either way, honestly, and one side or the other's going to be annoyed whichever way you do it, I guess. As long as it can be made to work properly without exotic workarounds, it's good, or at least not really a defect. You can suggest it as an option to switch the default behavior, but I really don't see that as coming in with a very high priority. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted March 4, 2011 Share Posted March 4, 2011 I think the default behavior should not show subtitles because if it did, then which language should it show as default? I imagine Spanish users would be upset if it showed English (for example). If the software was designed so it only opened subtitles of a certain language if present, that would require all video to be encoded with the same standards, which it's not, so the player might not be able to tell which external file represents which language, or which encoded subtitle to present. Some video has subtitles for the hearing impaired that describes sounds as well as the text of the voices, so it would get rather confusing. If you were happy with a previous version of our player because it behaved different, then you're more then welcome to revert to that version. Link to comment Share on other sites More sharing options...
vesnor Posted March 5, 2011 Author Share Posted March 5, 2011 Thanks for your help :) Link to comment Share on other sites More sharing options...
quicktimes Posted May 5, 2011 Share Posted May 5, 2011 If you were happy with a previous version of our player because it behaved different, then you're more then welcome to revert to that version. im having the same problem. i have uninstalled 5.1 and deleted the appdata and program files folder, reinstalled 4.9 but it wont autoload the subtitles like before anymore... :( the files i am playing are MKV with subtitles softsubbed into the mkv container with the video (not 1 mkv file and 1 subtitle file) Link to comment Share on other sites More sharing options...
kluelos Posted May 5, 2011 Share Posted May 5, 2011 Make sure that "Enable Subtitle Display" is checked under Options -> Play if you haven't already. Link to comment Share on other sites More sharing options...
quicktimes Posted May 5, 2011 Share Posted May 5, 2011 yes i have done that ive even turned the option off closed mpcstar open it up again and turned the option on again closed mpcstar played a video and it still doesnt work. :( Link to comment Share on other sites More sharing options...
hasnean Posted May 7, 2011 Share Posted May 7, 2011 Hi I have the oled mpcstar is work good but when i stup the new V 5.1 and when i load subtitle in arabic is show appears incorrect Link to comment Share on other sites More sharing options...
tobely2000 Posted May 30, 2011 Share Posted May 30, 2011 i solve this problem my friend first go back to mpcstar 4.9 and the arabic sub will be good then install 5.1 but when install unchech vobsub it will works good Link to comment Share on other sites More sharing options...
quicktimes Posted June 11, 2011 Share Posted June 11, 2011 (edited) mpcstar 5.2 is working great now! auto load subs, faster seeking, play speed reduction working! thanks :D Edited June 11, 2011 by quicktimes (see edit history) Link to comment Share on other sites More sharing options...
