Single-click Bookmarks
Okay, not sure if this was in the new release, but I notice when I left-click on the bookmarks it no longer has any functionality. I like populating the bookmark toolbar with my most common sites and have them start in a new tab with just a single click. In fact, I think it was smart where if you had dictionary.com up for example, and you would click on that bookmark, it would just reload that tab with dictionary.com up.
Now I have to right-click and have it open in a new tab.
Anyway to change it back to the way it was?
  • 3 weeks later...
I have the same problem with 4.0 I can open a bookmarked page with a right click and selecting whichever option but a double left click doesn't work.
And the same problem exists when I go to history and try to double click a browsed page.
i am also having this problem.. i am working on a fresh install.. the 3rd thing i installed was cometbird.. first was windows.. then was windows updates.. then was cometbird.. i am also using 3.6.16... i was using 4 but now i down graded to 3.6.16 to see if that helped.. it did not.. firefox 4 i can still single left click on bookmarks and it auto takes me there.. but cometbird i have to right click then left click to get any bookmark to work..
ok well i found a fix for my problem.. i uninstalled cometbird completely and then re-installed version 3.6.15 and now i can single click on my bookmarks again.. not sure if that would work for everyone.. but it worked for me..
  • 5 months later...
