goodiesguy Posted April 28, 2011 Share Posted April 28, 2011 just updated to cometbird 4 and my bookmarks refuse to show in the bookmarks menu. If i go to show all bookmarks and click bookmarks menu, they show, but i can not get them to appear in the bookmarks menu. Link to comment Share on other sites More sharing options...
goodiesguy Posted April 28, 2011 Author Share Posted April 28, 2011 Simply put, My bookmarks refuse to appear in the bookmarks pull down menu. Link to comment Share on other sites More sharing options...
iluvcomputers Posted April 28, 2011 Share Posted April 28, 2011 (edited) Simply put, My bookmarks refuse to appear in the bookmarks pull down menu. I've noticed too that whilst using cometbird. Try "show all bookmarks" and add them to the bookmarks toolbar. I imported my favorites from IE (which I rarely use as a browser, Firefox being my default) and then I can see them when I click on online bookmarks and then go down to the bookmarks toolbar. Hopes this helps! :) Edited April 28, 2011 by iluvcomputers (see edit history) Link to comment Share on other sites More sharing options...
kluelos Posted April 29, 2011 Share Posted April 29, 2011 If I understand what you're saying correctly, this is not new behavior. It's how Firefox (CometBird is Firefox) deals with imported bookmarks, by putting them into a subfolder. You can correct this using the "Organize Bookmarks" functionality, to copy (being safe, here) the bookmarks from their subfolder, to the main branch. Once you're satisfied they're working correctly, go back and delete the subfolder. Link to comment Share on other sites More sharing options...
stomachl Posted April 29, 2011 Share Posted April 29, 2011 I guess you're missing the point. Before CometBird 4, just click on the "bookmarks" menu (in between "history" and "Tools" on the menu bar), then all your bookmarks will appear on the drop down. Now, they're gone. They are in bookmarks->show bookmarks->bookmarks menu->then rightclick to open the pop-up menu then left click open to open that particular bookmark. Why mess it up in the first place? Link to comment Share on other sites More sharing options...
seekingfun Posted April 29, 2011 Share Posted April 29, 2011 why is my bookmarks in tabs not appearing after i exit from cometbird as early version i can have my tabs showing my entries Look like this version 4.0 is not user friendly Link to comment Share on other sites More sharing options...
goodiesguy Posted April 29, 2011 Author Share Posted April 29, 2011 I guess you're missing the point. Before CometBird 4, just click on the "bookmarks" menu (in between "history" and "Tools" on the menu bar), then all your bookmarks will appear on the drop down. Now, they're gone. They are in bookmarks->show bookmarks->bookmarks menu->then rightclick to open the pop-up menu then left click open to open that particular bookmark. Why mess it up in the first place? That's exactly my problem. Link to comment Share on other sites More sharing options...
kluelos Posted April 29, 2011 Share Posted April 29, 2011 Futher discussion here http://www.cometforums.com/topic/12796421-upgrade-bookmarks/page__pid__60837__st__0entry60837 Link to comment Share on other sites More sharing options...
