taichu Posted April 28, 2011 Share Posted April 28, 2011 I've opened my BitComet today and all of my downloads and settings have disappeard. It looked the same as when a new user downloads the program. My torrents are still in the download folder, I tried to add them to the program by "import unfinished download..." but it says "not found"!! Can the settings and downloads be resroted or I'll have to start from scratch?! Thanks *I'm using the newest version 1.27 maybe it's a bug? Link to comment Share on other sites More sharing options...
greywizard Posted April 28, 2011 Share Posted April 28, 2011 Tasks have disappeared/deleted tasks reappeared in my tasklist after a BitComet restart. How can I fix this? The FAQ is your friend; don't be afraid to use it. Link to comment Share on other sites More sharing options...
taichu Posted April 28, 2011 Author Share Posted April 28, 2011 Oh, sorry about the FAQ So what may be the reason for this to happen? I didn't do any upgrade to the OS or BC recently. Actually it happened before, I'm using BC for probably 5 years allready but I think I'll switch to uTorrent now... Link to comment Share on other sites More sharing options...
greywizard Posted April 28, 2011 Share Posted April 28, 2011 You don't need to make an upgrade in order for this to occur. It suffices that you shutdown Windows while BC is still exiting and this issue may occur. It's actually a matter of not being able to write on the disk the tasklist file. As you can read in the FAQ link, it's quite easy to fix if you use a version newer than v.1.18. Link to comment Share on other sites More sharing options...
