dirtyjobs93 Posted May 4, 2011 Share Posted May 4, 2011 Hi everybody. I have problem with port listening. Bitcomet cant listen ports which i opened. Other torrent clients can see that ports are opened. how can i solve this problem? I use Win7 and it has permission from firewall Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 4, 2011 Share Posted May 4, 2011 for starters click on the "READ THIS before posting" topic that's linked all over the forum. Link to comment Share on other sites More sharing options...
dirtyjobs93 Posted May 4, 2011 Author Share Posted May 4, 2011 (edited) for starters click on the "READ THIS before posting" topic that's linked all over the forum. ok i read it. 1) i use bitcomet 1.27 2) my connection is wan ethernet 3)i have Pirelli DRG A226G 4) Os is Win7. only windows firewall 5) speed test and now??? Edited May 4, 2011 by dirtyjobs93 (see edit history) Link to comment Share on other sites More sharing options...
kluelos Posted May 4, 2011 Share Posted May 4, 2011 You are connected via a combination modem and router, which contains a built-in firmware firewall. You will need to forward your chosen BitComet listen port through that firewall. Some instructions, which supplement the User Manual, can be found here: http://portforward.com/english/routers/port_forwarding/Pirelli/DRG-A226G/DRG-A226Gindex.htm These are supplemental to the manual. They do not replace reading and understanding the manual. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 5, 2011 Share Posted May 5, 2011 Also make sure bitcomet isn't using a listening port used by another program. Link to comment Share on other sites More sharing options...
