wavelink Posted May 21, 2011 Share Posted May 21, 2011 is anyone using this feature Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 21, 2011 Share Posted May 21, 2011 I don't know what feature your referring to. Link to comment Share on other sites More sharing options...
kluelos Posted May 21, 2011 Share Posted May 21, 2011 As far as I can determine, it has never worked properly. I think it was a predecessor to CometMarks, but was never developed. Since it doesn't work, nobody's using it or has really even asked about it before. Generally, that whole panel is out of date. The "Torrrent Sites" section hasn't been updated for years. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted May 21, 2011 Share Posted May 21, 2011 ah yes, kluelos is right. I assumed you were referring to cometmarks. Most of us pay no attention to that entire pane, but I agree it should be updated or simply removed. Link to comment Share on other sites More sharing options...
wavelink Posted May 21, 2011 Author Share Posted May 21, 2011 ok thanks just thought it would be handy as i use this alot Link to comment Share on other sites More sharing options...
kluelos Posted May 22, 2011 Share Posted May 22, 2011 CometMarks is actually handier. It moves your bookmarks to an external, web-accessible site, so that you can get to them from anywhere, or anyone's computer provided that you can install CometMarks on that computer. CometMarks' executable is small, so you can put it on a thumb drive on your keychain. Nice to be able to get to your bookmarks from anywhere. Link to comment Share on other sites More sharing options...
