Problem with subtitle encoding
Something on your system isn't encoding the aribic subtitles correctly. I don't personally know what has changed that could have caused this, but I'll leave your topic open and perhaps another member can help you.
In the meantime, if a prior version works, I'd recommend reverting back to it. Any bug fixes in new versions should be listed in the release notes, so I'd check them before updating to future version.
