VikingBeanBoy Posted June 20, 2011 Share Posted June 20, 2011 I have a spy keychain camera and it normally works fine but the one time something was stolen it won't work. It has the file followed by a bunch of others that say different minutes but with no kb on it and the top one has 909,000 kb is there anyway to combine them or am I just screwed? Link to comment Share on other sites More sharing options...
kluelos Posted June 20, 2011 Share Posted June 20, 2011 If all those files are indeed empty, then there's nothing to combine. If they are not empty, well, you could give it a try, but it is difficult to suggest how you might do that, without knowing what sort of files they are. Notice, you didn't say. You also didn't say what they're supposed to be. If a series of discrete images, your question likely answers itself. Link to comment Share on other sites More sharing options...
