help needed
... hi..
.. can anybody tell me what going on with my bitcomet 1.27..
..seem like i cannot download/upload since 3 days ago..
.. my log say something like this :2011-07-08 00:10:02 Tracker connection error: 10053 An established connection was aborted by the software in your host machine"
..by the way.. im using norton internet security 2010
Sounds to me like Norton is blocking the connection. To be sure try disabling it, if that works, then you need to set it to allow bitcomet full access outgoing, and and full access incoming on it's designated listening port.
You might find related posts on nortons user forum or FAQs
