rudiebotha Posted July 20, 2011 Share Posted July 20, 2011 I need some help please. I have been using mpcstar on all my movies for a long time now. About 3 weeks ago i lost the sound. When i play movies on any other like nero or windows then the sound are fine. I have unins. and reinstalled my mpcstar, but still there are no sound. I have recently donloaded mpcstar 5.1 and installed it, but still no sounI have looked at all my settings on mpcstar and everything seems fine. Iff theres any one who can help, i will apr. it. Thanks Link to comment Share on other sites More sharing options...
swon888 Posted July 30, 2011 Share Posted July 30, 2011 I also had this issue before, but I found the problem is with Real Player, if you have real player install, you need to uninstall Real Player, Uninstall MPCstar, reboot your system, than reinstall MPCstar, make sure doing the install, you check the real player codec check mark. DO NOT install real player again Link to comment Share on other sites More sharing options...
rudiebotha Posted July 30, 2011 Author Share Posted July 30, 2011 thanks for the help, but i dont know what was the problem. my sound has come back from the dead. i am watching movies on movies 2k. i have. one time i have putted the volume down and forgot to put it back on again. i went back to watch a movie and adjusted the sound. after that my mpcstar sound worked again. Thanks anyway Link to comment Share on other sites More sharing options...
marcosbressan Posted August 10, 2011 Share Posted August 10, 2011 The solution and the reason why sound suddenly stops working in MPCStar (TigerPlayer) is in my page: http://www.abcsense.com/mpcstaraudio.aspx Link to comment Share on other sites More sharing options...
