Sam704 Posted August 8, 2011 Share Posted August 8, 2011 Version 1.28 64 Bit ADSL internet connection Roouter, Cicso Windows Vista my bitcomet.exe file seem to dissappear for the V1.28 64bit. So I uninstalled the program and then reinstalled it. I now have the Comet.exe file but it will not work. I have a 64 bit computer, so I presume that I should use the 64 bit Version. What do you suggest. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 8, 2011 Share Posted August 8, 2011 Besides a 64bit processor in your computer, you also need a 64bit windows version. If you go to "Control Panel>System", one of the specs will say something like "system type: 64bit operating system" You can also get there by "right click" on "computer" and select "properties". Another way to tell is a 64bit windows version will have two program files folders on your C:\ drive. c:\program files(x86) c:\program files The 32bit version will only have one. Link to comment Share on other sites More sharing options...
kluelos Posted August 8, 2011 Share Posted August 8, 2011 Use of the 64-bit version is optional, if you're running 64-bit Windows. The installation can be tricky though, going from 32-bit to 64-bit and vice-versa. You must be careful with this and aware of what you are doing. Link to comment Share on other sites More sharing options...
