mudit4 Posted August 14, 2011 Share Posted August 14, 2011 Bit comet 1.28 ADSL connection (512 KBits/s) D-Link Glb 802-c Router Windows xp sp3 fully updated Norton 360 v5 windows firewall BC shows dht connected but it does not return any peer. (Photo uploaded bc.zip) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 14, 2011 Share Posted August 14, 2011 dht can only return peers if they exist. In this case, there probably are none. also, please save your screenshots as .jpg not .bmp, it will reduce the file size greatly, and please don't put them in .zip, it only makes more work for our volunteer staff. Link to comment Share on other sites More sharing options...
mudit4 Posted August 15, 2011 Author Share Posted August 15, 2011 thanks for your answer from next time i will use .jpg. My problem is not only for a particular torrent. Sometimes DHT do return me peers but most of the time it keep showing connecting even if there are thousands of peers across the dht network. (I found a temporary solution - keep updating the trackers and 1 out of 10 times dht returns me peers).Other bit torrent clients do return me peers of the same torrent at the same time. Link to comment Share on other sites More sharing options...
sharayde Posted August 15, 2011 Share Posted August 15, 2011 I also see that quite often the DHT does not return peers for a while even when other sources return peer lists quite quickly. There is a 20 minute timeout before DHT retries but it usually connects after a while and normally before the 20 minutes runs out. Won't trackers get upset if they see you repeatedly updating in a short space of time? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 15, 2011 Share Posted August 15, 2011 repeated update of trackers is called "hammering the tracker" and is considered hostile. Some trackers will block your IP address if you do this. As for dht, there is no tracker to update, so it's not as simple as getting a list from one central server Instead the lists are traded among connected peers. You can learn more by doing a search for "distributed hash table". Link to comment Share on other sites More sharing options...
