spicypuz Posted August 22, 2011 Share Posted August 22, 2011 hello i just got a usb modem and i ve got unlimited download but i cant seem to port foward.i get a speed of 40 - 50 kb/s but that is the max i can reach.my bitcomet shows me green light for dht and also green light for the WAN.pls can anybody teach me what i am not doing right as it is getting frustrating.this is what i get in my summary Up Time: 23:45:11 Overall Tasks: Total:15 / Running: 1 TCP Connections: Established: 70 [MAX:Unlimited] / Half-Open: 35 [MAX:200] LAN IP: 41.155.56.202 WAN IP: 41.155.56.202 Listen Port of TCP: 49000 (Opened in Firewall/Router) Listen Port of UDP: 49000 (Opened in Firewall/Router) Windows Firewall: Added [TCP opened, UDP opened, TCP(ED2K) opened, UDP(ED2K) opened] UPnP NAT port mapping: Failed [uPNP device not found!] Disk Boost Service: Running Overall Download Rate: 44 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task Overall Upload Rate: 2 kB/s [MAX:Unlimited] LT Seeding: 0 kB/s [MAX:Unlimited] All BT Upload Slots: 0 Free Phys Mem: 1.41 GB (Min to keep: 50 MB) Memory Usage: Working Set: 34.51 MB, Commit Size: 45.96 MB Disk Cache Size: 4 MB (Min: 6 MB, Max: 50 MB) Disk Read Statistics: Request: 476 (freq: 0.0/s), Actual Disk Read: 393 (freq: 0.0/s), Hit Ratio: 17.4% Disk Write Statistics: Request: 91336 (freq: 1.9/s), Actual Disk Write: 23452 (freq: 0.0/s), Hit Ratio: 74.3% Total Downloaded: 37.80 GB (this session: 1.61 GB) Total Uploaded: 2.81 GB (this session: 22.57 MB) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 22, 2011 Share Posted August 22, 2011 Quote also green light for the WAN If your Wan light it green, then there is no need to setup portforwarding. Link to comment Share on other sites More sharing options...
greywizard Posted August 22, 2011 Share Posted August 22, 2011 What brought you to the conclusion that something is wrong, in the first place? Link to comment Share on other sites More sharing options...
spicypuz Posted August 22, 2011 Author Share Posted August 22, 2011 So pls any idea if I can still increase M̶̲̥̅γ̲̣̣̥ download speed or is it not possible Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 22, 2011 Share Posted August 22, 2011 Please review the "READ THIS before posting" topic, specifically this section. Quote 7) For speed-related issues, please run various speed tests at a site such as speedtest.net (make sure that no other computer is using your Internet connection and that all other programs - including BitComet - are closed, during the tests). Include the results, along with the settings that you are presently using, in your post, so that we may review and offer suggestions to improve its performance. Link to comment Share on other sites More sharing options...
spicypuz Posted August 23, 2011 Author Share Posted August 23, 2011 my spped test result is download speed - 48 kb/s upload speed - 29 kb/s listen port 49000 and its open gen max download - unlimited gen max upload - unlimited and thats all i can figure out now.hope this information is sufficient.thanks for your time and help. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted August 23, 2011 Share Posted August 23, 2011 Can you please post a link to the speed test results, because I think you have your unit of measurements mixed up and I don't want to give you inaccurate advice. For example, a measure of 29kb/s is equal to less then 4kB/s. That's pretty slow so I suspect your test result was really 29kB/s. This will greatly change the recommended settings, so lets make sure we get it right. Link to comment Share on other sites More sharing options...
