BitComet Beta Plugins does not work in FF 4.01, 5.01, 6.0
Devil_Seed
Report BUG with Pics.
- main 1.28, test Beta20110826
- ADSL 6 Mbps
3) Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port?
- Router and Green Light
4) If you have more than one router, .....
1 x Router
- Windows XP SP3 lastest update with Microsoft Update
- "Malwarebytes PRO 1.51.1.1800" and "cFosspeed v.6.61 build 1881" and "SRS Audio Sandbox"
- FF 6.0 TH + BitComet Beta 20110826.
- FF 5.0.1 TH + BitComet Beta 20110826.
in - FF 4.0.1 TH + BitComet Beta 20110826 Does not work too.
{No pics}
- FF 4.01TH + BitComet 1.28 Work correctly.
BitComet is the best DownloadManager for me.
Thanks a lot sir.
Edited by Devil_Seed (see edit history)
