mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 (edited) magnet:?xt=urn:btih:1AEB356FC8CE7AE32AC99CF77CCA8DF15AF9FFB0&dn=Ben%2010%20Ultimate%20Alien%20-%20Cosmic%20Destruction.rar&tr=udp%3a//tracker.publicbt.com%3a80/announce&ws= http link these are the links for a new torrent as the links of the previous are now not under my control :) the links for the new torrents would be alive for at least 3 days from now this is a single file torrent and even then these links do not work for me. if you want then i may record a video of this whole process (how "I" did it) and upload it so that you may understand it properly Edited September 20, 2011 by mudit4 (see edit history) Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 Actually I just tried it on a popular torrent from thepiratebay and it worked perfectly. I'll also add that as soon as I entered the torrent it was instantly ready to download, so someone must have already done the task. I then opened the torrent in bitcomet and added it as a webseed and it is downloading. edit: I did some testing and if you run the link as an http task, their server will let you open upto 8 connections concurrently do you generated HTTP links using torrific and webseeded the torrent? does bitcomet fetched data from the http server? Was it a multiple file torrent? if yes than plz give me the torrent link and torrific link of that particular torrent Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 20, 2011 Share Posted September 20, 2011 I did it with torrific and it did webseed the single file torrent. I haven't tried it with multiple file torrents, if you do you may have to alter the link/s and they may need to be hosted on the same directory on torrific's website. For example, links like hxxp://torrific.com/yourfolder/torrentxxx/files/file0001.avi hxxp://torrific.com/yourfolder/torrentxxx/files/file0002.avi You would use this link... hxxp://torrific.com/yourfolder/torrentxxx/files/ Then bitcomet would know to download all of the torrents files from that location. If torrific puts them in completely separate locations, then I can't say if it would work or not, but you can try. Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 I just got a new idea. bitcomet might be programmed in a such way that it automatically searches for web seeds from sites like torrific.com it would definitely be useful specially when the torrent has low seeds/peers it might be added as a feature like LT or emule which searches for mirrors Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 I did it with torrific and it did webseed the single file torrent. I haven't tried it with multiple file torrents, if you do you may have to alter the link/s and they may need to be hosted on the same directory on torrific's website. For example, links like hxxp://torrific.com/yourfolder/torrentxxx/files/file0001.avi hxxp://torrific.com/yourfolder/torrentxxx/files/file0002.avi You would use this link... hxxp://torrific.com/yourfolder/torrentxxx/files/ Then bitcomet would know to download all of the torrents files from that location. If torrific puts them in completely separate locations, then I can't say if it would work or not, but you can try. the latest torrent i gave you is a single file torrent But still it do not work for me Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 (edited) plz give the link for the torrent you (The UnUsual Suspect) used Edited September 20, 2011 by mudit4 (see edit history) Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 20, 2011 Share Posted September 20, 2011 I'm sure the one I did has expired by now, but I'll make a new one and post the details as soon as I have time. I'll also try to get yours to work if you post the torrent and the link/s. Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 (edited) I just installed the beta version and the web seeding feature for the single file torrent is working well now you may not make another link for me. thanx for it But can you explain that how can i do it for multiple file torrent and torrific link as I can not change the torrific(http) link it the format you told me in you above post the http links are fixed (i think so) shall i add different http links for all the different files? Edited September 20, 2011 by mudit4 (see edit history) Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 can bitcomet be programmed in a such way that it automatically searches for web seeds from sites like torrific.com Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 20, 2011 Share Posted September 20, 2011 Yes, it already is, however the only way it can know of the existence of these ftp/http locations is if a bitcomet peer download them and has the options set to submit the mirror locations. This was added to bitcomet back in version 0.85 (approx), but it wasn't very successful at finding http/ftp mirrors, but the LTseed and emule mirrors were very successful, so that has been the focus of our efforts in recent versions. Torrent for you to demonstrate the webseeding from torrific.com web link http://u01.btaccel.com/833862c0e8/i:71.185.221.36,u:Vtm5rm8AXGfqAOa6ADq_,w:296200/9912/a38d02c287893842a32825aa866e00828a318f07/ubuntu-11.04-desktop-i386.iso Torrent magnet link magnet:?xt=urn:btih:UOGQFQUHRE4EFIZIEWVIM3QAQKFDDDYH&dn=ubuntu-11.04-desktop-i386.iso&xl=718583808 As a test, I removed all the trackers, disabled dht, ltseed, pex and emule, only allowing webseed peers and it's downloading fine, however torrific is a low bandwidth connection, most people will find little or no benefit to doing this. Link to comment Share on other sites More sharing options...
mudit4 Posted September 20, 2011 Author Share Posted September 20, 2011 I have got it working with single file torrent and want to know that how can i use it with multiple file torrent the feature i am saying would directly contact to torrific and search for links. it should not depend on other peers and torrific is not such a bad option when downloading with 8 connections you can easily get 1Mbps of speed I want bitcomet to search on other sites also torrific is not the only site which do this Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 20, 2011 Share Posted September 20, 2011 torrific would be a bad choice to search from, since the links expire so soon. By the time the links found their way into our database, they would be useless, creating bloat in our lists. If bitcomet had to test hundreds (if not thousands) of links looking for good ones, it would ruin the benefit of this option. Also, the link for a specific file cannot be searched until a bitcomet peer downloads that file and submits a hash value for it, that is the only way it could be indexed, and any index should be a location that is at least semi permanent, links that expire in days should have their domains blocked from our databases because they will do more harm then good. Regarding that torrent, any http connection I made to torrific's server varied in speed from 10 to 100kB/s, but if I add bittorrent peers, many of them download above 1000kB/s constant. Even if I run the torrific link as an http task and it lets me open 8 connections, I'm still limited to a max of 800kB/s, and that is only if all connections peak at the same moment, in reality I'm lucky to get half that at any moment. I'm sure paid users get much better speed, but this really isn't a good method of downloading. They do have a good idea though, it is no different then how a privately operated seedbox works. It runs the torrent remotely and lets you download the files using http after they are constructed from bittorrent pieces. The idea to operate it publicly is a good idea and I can certainly understand why free users are limited in bandwidth, but for most users, this negates any benefit. Where I do see a benefit of this is for users who don't know how to use torrents, or are on a firewalled connection, or one that is extremely limited upstream and cannot get good performance on torrents. One thing that concerns me is how they have coded their client that runs these torrents. For example, when BitComet begun our VIP server project, we designed it so the VIP server will become a valuable peer to the entire swarm. It's coded to upload at great speed so it can attract the best peers, then in the rare cases when it cannot upload a ratio above 1:1, it continues the task for upto two hours past completion (most tasks complete with ratio far above 1:1 and they only case where it wouldn't is if there was little or no demand for the files). It would be very easy for torrific to code their client to be a poor sharing client, and I sure hope that isn't what they have done. If they did do something like that, they would find many trackers blocking their IP addresses, as well as having their IPs distributed in popular blocking lists. ps. I already explained how to make it work with multiple torrent files. Link to comment Share on other sites More sharing options...
mudit4 Posted September 21, 2011 Author Share Posted September 21, 2011 Thanx for the explaination. But i still do not understand that how can make multiple file torrent work with torrific links because i can't edit the http links of torrific in the way you said. Plz explain me again I am giving you the magnet link and http link of a multiple file torrent i want to download on my desktop plz edit those links in such a way that when i paste them as web seeds they do their work. http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/AbSurDiTy.nfo http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy.avi http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/Torrent%20Downloaded%20from%20Extratorrent.com.txt http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/Torrent%20Downloaded%20from%20Idiotmp3.com.txt magnet:?xt=urn:btih:B2BF4TTAXRDWVT22IPEGBHGDYO42PEZQ&dn=The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy&tr=udp%3A%2F%2Fdenis.stalker.h3q.com%3A6969%2Fannounce&tr=http%3A%2F%2Fdenis.stalker.h3q.com%3A6969%2Fannounce&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.publicbt.com%2Fannounce&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.openbittorrent.com%2Fannounce&tr=udp%3A%2F%2Ftracker.istole.it%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.istole.it%2Fannounce&tr=udp%3A%2F%2Ftracker.ccc.de%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.ccc.de%2Fannounce&tr=http%3A%2F%2F10.rarbg.com%2Fannounce&tr=http%3A%2F%2Ftracker.novalayer.org%3A6969%2Fannounce&tr=http%3A%2F%2Fpow7.com%2Fannounce&xl=734288896 Link to comment Share on other sites More sharing options...
mudit4 Posted September 21, 2011 Author Share Posted September 21, 2011 Thanx for the explaination. But i still do not understand that how can make multiple file torrent work with torrific links because i can't edit the http links of torrific in the way you said. Plz explain me again I am giving you the magnet link and http link of a multiple file torrent i want to download on my desktop plz edit those links in such a way that when i paste them as web seeds they do their work. http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/AbSurDiTy.nfo http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy.avi http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/Torrent%20Downloaded%20from%20Extratorrent.com.txt http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy/Torrent%20Downloaded%20from%20Idiotmp3.com.txt magnet:?xt=urn:btih:B2BF4TTAXRDWVT22IPEGBHGDYO42PEZQ&dn=The%20Smurfs.2011.R5.LiNE.XviD.AbSurdiTy&tr=udp%3A%2F%2Fdenis.stalker.h3q.com%3A6969%2Fannounce&tr=http%3A%2F%2Fdenis.stalker.h3q.com%3A6969%2Fannounce&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.publicbt.com%2Fannounce&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.openbittorrent.com%2Fannounce&tr=udp%3A%2F%2Ftracker.istole.it%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.istole.it%2Fannounce&tr=udp%3A%2F%2Ftracker.ccc.de%3A80%2Fannounce&tr=http%3A%2F%2Ftracker.ccc.de%2Fannounce&tr=http%3A%2F%2F10.rarbg.com%2Fannounce&tr=http%3A%2F%2Ftracker.novalayer.org%3A6969%2Fannounce&tr=http%3A%2F%2Fpow7.com%2Fannounce&xl=734288896 Plz help Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 21, 2011 Share Posted September 21, 2011 You do it exactly how I said to do it in my previous post. Here is the link after I edited it http://u01.btaccel.com/ed41165374/i:59.177.36.141,u:ZRCmB86r1L7M5RGGFwhJ,w:296991/9916/0e825e4e60bc476acf5a43c8609cc3c3b9a79330/ I tried it on this task and it works. Link to comment Share on other sites More sharing options...
mudit4 Posted September 22, 2011 Author Share Posted September 22, 2011 thank you very much "The UnUsual Suspect" for all your hard work. Now finally i have got it working Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted September 22, 2011 Share Posted September 22, 2011 Glad to have helped, and enjoy bitcomet :) Link to comment Share on other sites More sharing options...
mudit4 Posted October 21, 2011 Author Share Posted October 21, 2011 Plz help me again this time i created a torrent and i think i did everything correctly but still it is not working here is the link for the torrent http://torrents.thepiratebay.org/6761022/New_folder_(3).6761022.TPB.torrent if it works for you then tell me and if it does not then please correct me! Link to comment Share on other sites More sharing options...
mudit4 Posted October 26, 2011 Author Share Posted October 26, 2011 Plz help me again this time i created a torrent and i think i did everything correctly but still it is not working here is the link for the torrent http://torrents.thepiratebay.org/6761022/New_folder_(3).6761022.TPB.torrent if it works for you then tell me and if it does not then please correct me! Anybody! Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted October 26, 2011 Share Posted October 26, 2011 It looks to me like you did it right, but the server is rejecting the webseed connection. I don't know why, but I'd guess it was setup with some kind of security to limit connections to only browsers. Try it with a server under your control, web seeding wasn't designed to be used by a 3rd party to distribut software from a publishers own website. Link to comment Share on other sites More sharing options...
